Home > Maintenance & Mods (L322) > over 2L of fluid from front diff |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
What colour was the oil?
29th Oct 2023 9:47am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3740 |
They probably took out the filling plug, then got distracted, came back to it and filled it up without draining the original oil ?
29th Oct 2023 10:10am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2385 |
The diff probably appreciated decent lubrication. |
29th Oct 2023 12:13pm |
The fill plug is also the level plug IIRC |
29th Oct 2023 1:25pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1452 |
They have probably adopted the level fill method to the plug (i havent tried to see how much it will actually hold). This isn't correct and instead the diffs take specified quantities.
29th Oct 2023 3:52pm |
From the L322 pages on Topix
29th Oct 2023 4:03pm |
Phoenix, I reckon the vehicle may have been jacked up. 2015 Range Rover Autobiography 4.4 SDV8 |
29th Oct 2023 4:11pm |
I was wondering if it'd drawn any water in (hence asking about the colour), used to get that on the old Defenders if the breathers had been blocked or re-routed to create a 'U' bend, which would effectively block the breather, causing a hot diff suddenly quenched by cold water, to draw in water past the seals... |
29th Oct 2023 6:49pm |
BLRover Member Since: 15 Oct 2023 Location: Tennessee Posts: 17 |
Appreciate the input!
29th Oct 2023 8:10pm |
