Home > Maintenance & Mods (L322) > L322 4.4 TDV8 60k service
EOD Steve
United Kingdom 2012 Range Rover Vogue TDV8 Sumatra Black
Hi all,
What sort of items are changed / checked / etc on a 60,000 mile service please?
Mileage currently 57888
New Oil cooler fitted in June this year with 55568 miles.
(Would another oil / filter change be required taking into account above comment?)
For a service including oil which local indy has suggested should be done, they have quoted £480 + VAT.
Your thoughts appreciated,
Steve 4.4 TDV8 Sumatra Black + Ivory Leather
Post #676486 26th Oct 2023 11:39am
JayGee
It's not the mileage but the age that will determine the service and what has been done before your ownership? Most people change their oil at between 5 and 7 k miles on these and it's an easy DIY job with a Draper oil extractor so no need to pay a garage or do it for a while.
If it was mine and I had no service history ;
Thorough inspection by a LR specialist
Cabin filter and 2x air filter
Fuel filter
Brake fluid
Battery
Both diffs and transfer box
Gearbox service or 'megaflush'
Replace tyres if over 5 yrs old and any age related cracks
Wiper blades
4 wheel alignment
Software update to gearbox
Clean MAP sensor 2012 TDV8 Vogue (L322)
Post #676495 26th Oct 2023 2:57pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
What is a "software update to the gearbox" and what is the effect if any ?
Sorry for my poor computer knowledge. RR owner
Post #676511 26th Oct 2023 7:44pm
garyRR
Similar to JayGee's suggestion, I would add it depends what has been done before also. If there's no evidence of something being done, I'd add that to the service.
A good service schedule to follow is:
Every 1,000 miles
Clean the MAP sensor
Inspect the 4x air intake manifold hoses, plus charge hoses and throttle body union for soot build up, white gunk or splits
Check tyres and pressures
Every 5,000‐7,000 miles
Oil and filter change
Every 10,000-15,000 miles
Air filters, pollen filter
(Plus oil and filter change)
Every 2 years or 25,000 miles (whichever is sooner)
Fuel filter
Diff oils
Transfer case fluid change
Every 5 years or 50,000 miles
Transmission fluid and filter
Auxiliary belt and tensioner (check, only replace if noise and/or visible wear to belt - may not be required until 10 years/100,000 miles)
Personally, I service the vehicle myself. Unlike anything else on a Range Rover, servicing them is actually really simple (with the exception of transmission fluid and filter) and requires little more than a socket set and a screwdriver.
Oil and filter costs me about £60
Air filters cost me about £17
Pollen filter is about £20
Fuel filter is normally about £30
2L diff oil costs £22
Transfer case fluid costs £27
Genuine ZF Transmission Service kit £200
Auxiliary belt, fan belt, tensioner and pulleys kit £180 2015 Range Rover Autobiography 4.4 SDV8
Post #676555 27th Oct 2023 2:02am
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
Sorry to jump in on someone else’s thread with a question.
The service schedule breakdown is great so thanks for sharing. What symptoms does a dirty map sensor exhibit? Mine has not been cleaned since owning the car (1 year and a couple of thousand miles but I have never cleaned the map sensor). Is brake cleaner ok to use.
Thanks 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #676570 27th Oct 2023 9:52am
JayGee
A bit of hesitation during throttle applications. Brake cleaner is fine to use. 2012 TDV8 Vogue (L322)
Post #676571 27th Oct 2023 9:57am
DrRob
I use brake cleaner. 5 min job. Worth doing Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2025MY Defender D350 90 in Silcon Silver on coils
Post #676585 27th Oct 2023 11:21am
JayGee
Dealer or indy with dealer level diagnostic kit will update the programming ( for a small fee). Mine felt better but couldn't put my finger on why? Probably worth doing but maybe not essential. The gearbox went into later cars so likley new software reflects tweaks and improvements over many more years that the 2 it had in the L322. 2012 TDV8 Vogue (L322)
Post #676589 27th Oct 2023 11:33am
