Home > Maintenance & Mods (L322) > 4.4 tdv8 LH air inlet manifold replacement
Downhillerffrr
My inlet manifold is split where it joins the plenum chamber hoses and I’m going to replace the inlet manifold. Other than ordering the manifold and gasket is there anything else that needs replacing to complete the job? Any top tips also welcome.
Post #676302 24th Oct 2023 12:36pm
Baltic Blue
Several of manifolds have been reported as splitting near the short plenum hose, but I can’t remember actually reading a detailed report (with pictures) of the job to replace one, so hope you are willing to take lots of pictures so we can all learn .
Good luck,
Cheers
Mike.
One point, have you got the very common EGR temp fault code PO40D-00 (2F) showing??
Just thought changing the failed sensor would be much easier whilst you have the inlet manifold etc removed.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #676306 24th Oct 2023 2:08pm
Downhillerffrr
No fault codes at all in the IID tool. Just a pop sound as it went into Restricted Performance mode as I pulled away from a roundabout and now I see the split in the intake just like others have had. I’ve scanned it for fault codes multiple times but it doesn’t come up with any other than the usual standard ones.
Post #676319 24th Oct 2023 4:15pm
Downhillerffrr
Post #676320 24th Oct 2023 4:16pm
JayGee
Can't see where the split is. Is it along the seam separating the upper and lower part or a circular split ? If it was mine I'd be attempting to repair it in situ with a sleeve and or some strapping and epoxy glue as AFAIK removing the whole intake is a pig of a job 2012 TDV8 Vogue (L322)
Post #676324 24th Oct 2023 4:49pm
Downhillerffrr
This shows it better. It’s begun to split further round.
Post #676325 24th Oct 2023 5:04pm
Phoenix
Anything you do to 'fix' that will only be of a temporary nature, replace it now before it goes from inconvenience to full-blown journey-stopper.
You'll need the copper injector seals - Bosch F 00V C17 503 - if you search you can find them a lot cheaper that >£22 for eight! I'd also recommend replacing the leak-off 'O'ring seals LR022994 but don't buy them from LR!
The manifold should come with the gasket pre-fitted, just make sure everything is fully clean and give it a swipe of red rubber grease before fitting. It's not too different a job to the 3.6TDV8 so you can probably read-up on that to see what to expect.
Post #676326 24th Oct 2023 5:22pm
Downhillerffrr
Phoenix thanks for the reply and the useful info re the washers and the model numbers for them. Reading the LR workshop manual it states I need an alignment tool for the injector ports in the manifold to hold it in place whilst it’s torqued up by the look of it. My previous experience of such special tools is that I’ve not needed them. Did you use an alignment tool? I’ll be replacing the whole manifold as a repair would only be temporary, as you say.
Post #676330 24th Oct 2023 5:58pm
Downhillerffrr
is the foam cover bonded to the manifold somewhere? It feels that it may be attached at the bottom
Post #676332 24th Oct 2023 6:00pm
JayGee
Depends on how good the repair is. It's a plastic part and doesn't take any mechanical load and the gap is not going to turn into a gaping hole or cause the intake to fall off. If you were going the 'whole hog' then do both sides. 2012 TDV8 Vogue (L322)
Post #676336 24th Oct 2023 6:16pm
Phoenix
The 'special tool' is just a close-fitting round bar that goes in an injector port, every time I've done them I've just used two (clean!) injectors in alternate ports - never had a problem.
WRT repairing, there is a mechanical load, it's the load (pressure) that caused the split in the first place, coupled with the resultant contamination of the joint surfaces and the potential weakening of the welded joints around the one that has split. It's a plastic part that has had oily, hot air & exhaust gases pushed through it, has been heated and cooled repetitively for >10 years, what could possibly be a worse candidate for a temporary bodge?
Post #676343 24th Oct 2023 6:35pm
JayGee
Doesn't have to be a 'bodge' or temporary - depends on what you do and are capable of. 2012 TDV8 Vogue (L322)
Post #676347 24th Oct 2023 6:47pm
Phoenix
From memory, no - it might just have lost a bit of pliability with age and be stuck on an injector pipe or wiring harness etc.
Post #676348 24th Oct 2023 6:48pm
Downhillerffrr
Thanks Phoenix
Post #676366 24th Oct 2023 8:12pm
Dolphinboy
Had one done a few years ago. Parts numbers here.
Post #676377 25th Oct 2023 12:05am
