Home > Technical (L322) > radiator fan |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Jeśli przełącznik ciśnienia czynnika chłodniczego zostanie wykryty jako uszkodzony, wentylator będzie pracował z pełną prędkością, ponieważ nie można wykryć ciśnienia. Odłącz przełącznik i powinien zatrzymać wentylator.
23rd Oct 2023 7:48pm |
laska7711 Member Since: 23 Oct 2023 Location: Kruszyn Posts: 7 |
the car has had its air conditioning serviced, so there shouldn't be too much pressure. |
23rd Oct 2023 7:52pm |
tell me where this sensor is |
23rd Oct 2023 7:55pm |
It's on the AC pipe on the (EU) passenger side near the fuel injectors. It's possible the system has been overcharged, this would also cause the problem, as would a faulty sensor indicating too much pressure. |
23rd Oct 2023 8:47pm |
The air conditioning pressure sensor is operational and shows 7 Bar in the system. No ideas. Should the replaced fan be attributed to the computer? |
24th Oct 2023 6:14pm |
Do you mean the electric or the viscous coupled fan? both will work without programming but the diagnosis is different. |
24th Oct 2023 7:57pm |
Hello, I'm talking about the electric AC fan, after starting the car it works at full power regardless of whether the air conditioning is on or not. After connecting the computer, it does not report any errors. It was changed because the old one didn't work at all. |
25th Oct 2023 3:54am |
You didn't mention that previously!
25th Oct 2023 6:27am |
I disconnected the cable and then the fan stops working, and the error appears as a break in the fan control. The engine temperature sensor shows that it is OK, there are no errors related to the air conditioning. The fan is the second one because the first one didn't work so I'm out of ideas. |
25th Oct 2023 6:56am |
Hello, problem solved, damaged fan controller. Replaced with another one and the problem was solved. |
10th Dec 2023 6:04pm |
