Home > Technical (L322) > radiator fan
laska7711
Poland
radiator fan
Hello, after starting the fan motor, it runs at full frequency. No reaction when the effect is turned on or occurs. Do you have any ideas L322 2007 3.6 TDV8
Post #676258 23rd Oct 2023 7:42pm
Phoenix
Jeśli przełącznik ciśnienia czynnika chłodniczego zostanie wykryty jako uszkodzony, wentylator będzie pracował z pełną prędkością, ponieważ nie można wykryć ciśnienia. Odłącz przełącznik i powinien zatrzymać wentylator.
I hope the translator worked OK!
Post #676259 23rd Oct 2023 7:48pm
laska7711
Poland
the car has had its air conditioning serviced, so there shouldn't be too much pressure.
Post #676261 23rd Oct 2023 7:52pm
laska7711
Poland
tell me where this sensor is
Post #676263 23rd Oct 2023 7:55pm
Phoenix
It's on the AC pipe on the (EU) passenger side near the fuel injectors. It's possible the system has been overcharged, this would also cause the problem, as would a faulty sensor indicating too much pressure.
Post #676269 23rd Oct 2023 8:47pm
laska7711
Poland
The air conditioning pressure sensor is operational and shows 7 Bar in the system. No ideas. Should the replaced fan be attributed to the computer?
Post #676335 24th Oct 2023 6:14pm
Phoenix
Do you mean the electric or the viscous coupled fan? both will work without programming but the diagnosis is different.
Post #676364 24th Oct 2023 7:57pm
laska7711
Poland
Hello, I'm talking about the electric AC fan, after starting the car it works at full power regardless of whether the air conditioning is on or not. After connecting the computer, it does not report any errors. It was changed because the old one didn't work at all.
Post #676381 25th Oct 2023 3:54am
Phoenix
You didn't mention that previously!
The thin black-green wire is the control wire, disconnect that and see what happens - if no change it could be a bad internal connection on the fan or a faulty fan, can you try plugging in a known good one?, the fan is controlled by the engine control module, not the climate control module, so it may not be linked to refrigerant, it may be a coolant temperature sensor problem.
Post #676384 25th Oct 2023 6:27am
laska7711
Poland
I disconnected the cable and then the fan stops working, and the error appears as a break in the fan control. The engine temperature sensor shows that it is OK, there are no errors related to the air conditioning. The fan is the second one because the first one didn't work so I'm out of ideas.
Post #676387 25th Oct 2023 6:56am
laska7711
Poland
Hello, problem solved, damaged fan controller. Replaced with another one and the problem was solved.
Post #680000 10th Dec 2023 6:04pm
