Home > Technical (L322) > Rear bearing hub removal |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 110 |
Just had mine replaced by a local garage, you don’t need a puller you need a 20-30 tonne press from what they told me. Not easy to set up either due to the irregular shape of the knuckle. Kevin
17th Oct 2023 2:47pm |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 399 |
i am replacing the entire hub, not the bear alone, so pulling the hub out is the only real "hard" bit.
17th Oct 2023 2:48pm |
