Home > Technical (L322) > Rear bearing hub removal
mgrover
Hello,
Ill be doing the rear bearing hub removal soon since the back left is whining so thought lets just do both since am also doing the brake discs on both.
anyone know what bearing puller size would be appropriate?
Cheers
Martin Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #675702 17th Oct 2023 7:02am
Epson Green
Just had mine replaced by a local garage, you don’t need a puller you need a 20-30 tonne press from what they told me. Not easy to set up either due to the irregular shape of the knuckle. Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #675738 17th Oct 2023 2:47pm
mgrover
i am replacing the entire hub, not the bear alone, so pulling the hub out is the only real "hard" bit.
it seems a 3 jaw puller is perfect for it but unsure what size.
edit: on further inspection your right, and am guessing am screwed Laughing
i wonder if its possible to remove it while in situ in the car. i don't really fancy undoing the entire knuckle. Its actually a sport Sad
Post #675739 17th Oct 2023 2:48pm
