Home > Maintenance & Mods (L322) > Car failed mot
disco 3.5
Car failed mot
Big Cry I’ve got a dilemma, I’ve been quoted just over 2k to sort out corroded breaks and corroded hand break, my 2009 Westminster is probably only worth about 4-5k is it worth having the work done or strip car for parts, Engines only done 117000 and still drives like a limo LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #675657 16th Oct 2023 5:26pm
JayGee
If you think you can get a better car for £2k + the trade in on yours then get rid of it. I suspect not Whistle 2012 TDV8 Vogue (L322)
Post #675660 16th Oct 2023 5:42pm
disco 3.5
is 2k about right for brakes replacement? It passed last year no advisories! LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #675662 16th Oct 2023 5:53pm
disco 3.5
Booked in to another Garage for second opinion and a second quote LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #675664 16th Oct 2023 6:31pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
If you can do it yourself its about £500 of parts.
Post #675665 16th Oct 2023 6:32pm
disco 3.5
I wish I could but unfortunately it’s way above my knowledge, the garage says they have to lift the body to complete work is that correct? LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #675667 16th Oct 2023 6:53pm
JayGee
Find another garage as saying they need to lift the body off the chassis indicates they don't have any specialist knowledge of these vehicles. 2012 TDV8 Vogue (L322)
Post #675668 16th Oct 2023 7:00pm
philip1972
I think I may have misunderstood-maybe you are needing new brake lines.
Ignore me Rolling with laughter
Post #675669 16th Oct 2023 7:01pm
disco 3.5
The 2 guys told me they worked at JLR for 20 and 10 years respectively LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #675670 16th Oct 2023 7:02pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
Seriously take it for another MOT elsewhere, mine passed with one advisory which wasn't even mentioned by the garage that failed it three days before because of allegedly serious problems.
It really can be a bit of a lottery. RR owner
Post #675671 16th Oct 2023 7:09pm
mjdronfield
Yes, you can’t take the body off an L322. It’s the old L320 sport and Discovery that was on a separate chassis and the body could be lifted off.
Maybe they mean they would drop the sub frames, but that’s a pretty big job just to run brake lines. Assuming it’s brake lines that need doing.
There is a how to in the Wiki… I know you say you can’t do it yourself, but at least it will give you an idea of the work involved to gauge garage quote…
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #675674 16th Oct 2023 7:42pm
garyRR
Find another garage at once and don't waste any more money with these people. There are FAR too many Land Rover "specialists" who don't have the foggiest about the models, but just want to justify a higher hourly labour rate. It's not difficult for a specialist to know the L322 is a monocoque.
Any garage should be able to replace and bleed the brake lines for you, without a £2,000 bill. Although I'd be surprised the solid lines have had it at that age and mileage. Are you sure it's not the flexi ends going to the calipers?
Your original post isn't the most descriptive. By corroded you could mean corroded discs, corroded pistons on the calipers causing them to seize, or the flexi hoses. By the handbrake, I assume you mean the parking brake mechanism is seized and needs cleaning out, new shoes and unjamming to see if the mechanism will work (I got a quote for this once and this part was £180 from a local tyre/brakes/exhaust place, including new shoes). 2015 Range Rover Autobiography 4.4 SDV8
Post #675677 16th Oct 2023 8:12pm
Gary, you'll find tonnes of 2009 322's with absolutely goosed brake hard lines my friend! JLR have never changed from using painted/coated steel brake lines. Since I can remember we have been changing hard lines from 4-5yrs old onwards!!!
Disco 3.5, If the garage have told you "they need to lift the body" RUN! They clearly have no idea what they are talking about sir...
Post #675692 16th Oct 2023 10:25pm
gettingold
Why don't you put out a post asking the collective knowledge where to take your car. Others will recommend go here or there, which may be better than a stab in the dark. visiting from www.rrsport.co.uk
Post #675696 17th Oct 2023 6:17am
Fox889
As everyone has already said, if they say “we need to lift the body” then quite frankly my dear they don’t have a bloody clue! Simple as that. Ask for proper Indy recommendations in your area & try them. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #675703 17th Oct 2023 8:04am
