Home > Maintenance & Mods (L405) > Replacement Headlight "bulbs"
Page 3 of 5 <12345>
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Remove the six air box screws and remove the top. Undo the banjo air hose clip and push back the hose. Don’t disconnect any wires, just put it out of your way.You can now remove the bottom part.
First pull up the engine end, there’s a push in/out lug on the bottom. Then pull it away away from the wing and take it out. Two pull out/in lugs here. . Then the back bulb cover is exposed. For some reason, I also removed the solid air pipe to the turbo inlet (cover the hole) but offside only. It will all become obvious once you start. HTH. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #675426 12th Oct 2023 5:24pm
Thanks - due on Monday so not too long to wait. Looking forward to fitting & trying them.
Post #675430 12th Oct 2023 6:18pm
Phoenix wrote:
They're just the light source, the optics (and shutter) in the headlamp assembly determine where the light is positioned on the road.
I was worried that the brighter bulbs may cause an issue - I guess I'll find out soon enough.....
Post #675431 12th Oct 2023 6:19pm
Phoenix
They shouldn't do - it's just more light in the same place. I've done a fair bit of night driving since fitting to mine and there's been no issues with disgruntled oncoming traffic.
Post #675432 12th Oct 2023 6:22pm
GrandadRob
Sorry, I forgot to say….. Before actually removing r the old bulbs, there is a lever beside the base of the bulb, which must be slid downwards to unlock the bulb. After fitting the new one, the lever must go up again. 2013 SDV8 4.4 SE Luxor.
Post #675433 12th Oct 2023 6:26pm
Post #675434 12th Oct 2023 6:28pm
All fitted - as others have said, it was a little bit fiddly, but not overly difficult.
I just need to wait for it to go dark now Laughing
Post #675625 16th Oct 2023 10:55am
GrandadRob
Thumbs Up 2013 SDV8 4.4 SE Luxor.
Post #675629 16th Oct 2023 11:11am
I'll file this one under jobs I should have done a long time ago..... preferably when I used to do a lot of driving in the dark Confused
I was not particularly unhappy with the headlights, but these are noticeably brighter and whiter. I passed 10 or so cars on my way home and none of them flashed at me, so I assume from that small sample that they are OK.
Thanks all Thumbs Up
Post #675809 18th Oct 2023 2:00pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
I’m keeping a watchful eye on this thread as I’d like to upgrade my 2016 L405 lights. I find them…..not good! What’s the best solution currently in offer for a L405?
Isn’t there something in the new MOT rules that outlaws leds? Or is that for something else? L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #676231 23rd Oct 2023 3:47pm
Gremlin500
I just fitted these:
AliExpress:£29.25 58% Off | D1S D3S LED innovative 3 copper tube canbus 140W 6500K white D2S D4S D3S D1R D2R D3R D4R12V LED TO HID LED headlight
https://a.aliexpress.com/_EQrLH3p
Yes, that price is for TWO leds, they aren’t exactly exquistely put together, but seem to work OK so far, way brighter than my already upgraded Osrams, (think 4x-6x) and who can argue at that price? Fans are silent, heatsinks are slightly tricky to align with all the little spring-clips. Very white light, good spread, very flat beam cut-off. 2-3 weeks to the UK. Worth a punt.
140W = 2 bulbs, 70W each. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #676236 23rd Oct 2023 4:24pm
knwatkins
I'm trialling these at the moment...
https://www.aliexpress.com/item/1005005227734418.html
Arrived in a 5 days. Pretty impressed so far. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #676256 23rd Oct 2023 8:29pm
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
I'd like a warm/daylight LED colour output temperature, not a "cold" one.
Any idea what that would be? 2012 Supercharged L322
Post #680866 20th Dec 2023 11:33pm
Gremlin500
Google "colour temperature chart"
Look for “images”. Thumbs Up
I’d say 4000K-5000K is “warm”, and 5000K-6000K is “white”. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #680872 21st Dec 2023 3:20am
OE bulbs are 4300k..... ... - .- -.
Post #680877 21st Dec 2023 9:15am
Page 3 of 5 <12345>
