Help with ECU no communication | |
Hi, I was wondering if anyone could help me pinpoint an issue with an L405.
Intermittently the engine will completely switch off while driving and the dash goes nuts lighting up like a Christmas tree everything goes into fault.
I've checked the grounds in the wheel arches and the ones in the engine bay (behind the air box and the ones up by the bulkhead ) as well as the strap that goes on to the transfer/gearbox
As I'm not as familiar with these would someone be willing to help me work threw this
I would like to add this is low milage 60k and when I checked the earth points even though they looked OK (no sign of corruption at all) I still removed them cleaned them and refitted them regardless, and both batteries have been replaced as they were testing bad
There is a flash/burn mark on the posertive battery connector from where its been jump started
I will put the dish scan data below
Its a pain its so intermittent when im checking powers grounds and scoping the fault does not happen to see it only appears to happen while driving
Many thanks
TGS3s
System type Status Faults
ABS - - (ABS) Antilock braking system [--/13>--/14] - P YES
• U0001 - 87 High Speed Controller Area Network Communication Bus -
Message missing MEM -
• U0001 - 81 High Speed Controller Area Network Communication Bus -
Received serial data non valid MEM -
Adaptive Cruise Control - - (CCM) Cruise Control Module [--/13>--/16] Adaptive
speed control P YES
• U0100 Lost Communication With ECM/PCM "A" MEM -
• U0415 - 81 Invalid Data Received From Anti-Lock Brake System (ABS) Control
Module - Received serial data non valid MEM -
• U0418 - 68 Invalid Data Received from the Brake System Control Module -
Event information MEM -
Adaptive Cruise Control - - (CCM) Cruise Control Module [--/13>--/16] Speed
control P YES
Air conditioner - - (HVAC) Heating, Ventilation and A/C [--/13>--/13] - P YES
• B12A6 Auxiliary heater water pump status ATT -
• B13C2 Front Windscreen/Windshield Misting Sensor ATT -
Air conditioner - - (HVAC) Heating, Ventilation and A/C [--/14>] - P YES
Airbag - - (RCM) Restraint Control Module [--/13>--/16] - P YES
Audio amplifier system - - (AAM) Audio amplifier module - - P NO
Audio control - - (ACM) Audio control module [--/13>--/16] - P NO
Automatic transmission - - (TCM) Transmission control module [--/13>--/16] - P YES
• U0100 - 63 Lost Communication With ECM/PCM "A" - Circuit/component
protection timeout MEM -
Body Computer - - (BCM) Body Control Module - - P YES
• U0155 Lost communication with the instrument panel control unit MEM -
• U0164 Lost Communication With Heating Ventilation Air Conditioning
Control Module MEM -
• U0199 Lost Communication With Door Control Module A MEM
• U0230 Lost Communication With Rear Tailgate Module MEM
Central console controls - - (FCIMB) Front controls interface module B - (HV
AC)
Heating, Ventilation and A/C controls
P NO
Central console controls - - (FCIMB) Front controls interface module B - Front
audio control panel
P NO
Central console controls - - (FCIMC) Front controls interface module C - Front
audio control panel
P NO
Chassis management system - - (CHCM) Chassis control module - -
P YES
• U0402 Invalid data received from transmission control unit MEM
• U0415 Invalid Data Received From Anti-Lock Brake System (ABS) Control
Module MEM
Chassis management system - - (CHCMB) Chassis control module B [--/13>-
-/13] -
P YES
Module MEM
Chassis management system - - (CHCMB) Chassis control module B [--/14>-
-/16] -
P YES
Module MEM
Diesel injection Bosch 17 CP 11 EDC - With DPF - Euro 5/Euro 6
P YES
• P0700 Transmission Control System (MIL Request) MEM
Digital radio tuner - - (DBAM) Digital radio transmission control unit [--/13>-
-/16] -
P NO
Driver side door - - (DDM) Driver Door Module - -
P NO
Driver side pretensioner - - (SPMA) Pretensioner driver side - -
P NO
Dynamic drive control - - (ATCM) All terrain control module [--/13>--/16] -
P YES
• U3003 - 62 Battery voltage - Signal comparison failure
AT
T
Front camera - - (HCMB) Headlight electronic control unit - Module B - With
front camera [--/14>--/15] High Line
P NO
front camera [--/14>--/15] Low Line
P NO
Front interface module - - (FCDIM) Front Control Display Interface Module [-
-/13>--/15] -
P NO
-/16>] -
P NO
Gateway - - (GWM) Gateway Module [--/13>--/13] Dual battery
P NO
Gateway - - (GWM) Gateway Module [--/13>--/13] Single battery
P NO
Gateway - - (GWM) Gateway Module [--/14>--/16] -
P NO
Gear selector lever - - (GSM) Electronic Gear Selector Module [--/13>--/16] -
P YES
Headlight adjustment - - (HCM) Headlight Control Module - -
P NO
Immobilizer - - (VIM) Vehicle immobilizer control module - -
P NO
Instrument panel - - (IPC) Instrument Panel Cluster - -
P YES
Keyless go system - - (RFA) Keyless vehicle module - -
P NO
Lower liftgate - - (R
GTMB) Rear Gate/Trunk Module - -
P NO
Navigation system - - (NCM) Navigation control module [--/13>--/15] -
P NO
Navigation system - - (NCM) Navigation control module [--/16>--/16] -
P NO
Parking aid cameras - - (IPM-B) Image Processing Module [--/13>--/15] -
P YES
• U0140-08 - Lost communication with the Body Computer - Bus
signal/message malfunction MEM
Parking aid cameras - - (IPM-B) Image Processing Module [--/16>] -
P YES
Parking brake - - (PBM) Parking Brake Module - -
P YES
Parking help - - (PAM) Parking Assist Module [--/13>--/16] -
P NO
Passenger side door - - (PDM) Passenger Door Module - -
P NO
Passenger side pretensioner - - (SPMB) Passenger side pretensioner - -
P NO
Passenger side seat adjustment - - (PSM) Passenger Seat Module [--/13>--/13] -
P NO
Passenger side seat adjustment - - (PSM) Passenger Seat Module [--/14>--/15] -
P NO
Passenger side seat adjustment - - (PSM) Passenger Seat Module [--/16>--/16] - P NO
Power steer - - (PSCM) Power Steering Control Module [--/13>--/16] - P NO
Rear air conditioner - - (HVACR) Heating, Ventilation and Air Conditioning, Rear
compartment - -
P NO
Rear left seat adjustment - - (RLSM) Rear left seat module [--/13>--/13] - P NO
Rear left seat adjustment - - (RLSM) Rear left seat module [--/14>--/15] - P NO
Rear multimedia system - - (REM) Rear entertainment [--/13>--/16] - P NO
Rear right seat adjustment - - (RRSM) Rear right seat module [--/13>--/13] - P NO
Rear right seat adjustment - - (RRSM) Rear right seat module [--/14>--/15] - P NO
Satellite radio tuner - - (SRM) Satellite audio unit module [--/13>--/16] - P NO
Seat adjustment, driver's side - - (DSM) Driver Seat Module - - P NO
Seat air conditioning/heating adjustment - - (SCME) Front seat climate control
module [--/13>--/13] - P YES
• U0140 Lost Communication With Body Control Module MEM -
Steering angle sensor - - (SAS) Steering Angle Sensor control unit [--/13>--/16] - P NO
TV tuner - - (TVM) Television Module [--/13>--/16] - P NO
Torque transfer box - - (TCCM) Transfer Case Control Module [--/13>--/13] - P YES
Torque transfer box - - (TCCM) Transfer Case Control Module [--/14>--/16] - P YES
Tyre pressure - - (TPM) Tyre Pressure Monitoring [--/13>--/15] Body computer P YES
• U0199 Lost Communication With Door Control Module A MEM -
• U0230 Lost Communication With Rear Tailgate Module MEM -
Upper liftgate - - (RGTM) Rear Gate/Trunk Module - - P NO
(Hands-free) boot opening request system -- --
Calf rest support module -- --
Differential lock electronics -- --
Driver and passenger side running board -- --
Driver side rear door -- --
Head-up display -- --
Obstacle detection control unit, left side -- --
Obstacle detection control unit, right side -- --
Occupied seat detection -- --
