![]() | Home > Maintenance & Mods (L322) > Painting Scuttle Panel - Advice Sought. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
Cant help with recommendations, but will follow this as I want to do mine |
I used this trim restorer on mine a few years ago and surprisingly it is still black.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3868 ![]() ![]() ![]() |
http://www.fullfatrr.com/gallery/albums/us...C00622.JPG
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
All I'll say is it will take less time to remove it than it does to mask it up, you will also get a better job done off the car. If you do do it on the car don't forget to put paper under the vent, inside the bonnet....
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 ![]() ![]() |
As a model maker I wouldn't use the Humbrol enamels as I think it would spider Web crack on you. I can't recommend any other paint though. There's got to be something out there.... https://www.google.co.uk/search?q=aerosl+s...nt=gws-wiz visiting from www.rrsport.co.uk |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
OK, thanks for the comments all. I have decided to take @nicedayforit's suggestion and give trim restorer one last try.
DanRRL322sc Member Since: 16 May 2022 Location: Bedfordshire Posts: 55 ![]() ![]() |
How did this work out? I too am fed up with the light grey/white plastic look that returns every 3-4 months after using plastic trim restorer on it! |
Not done yet Dan. Life intervened. Will be done on the weather-acceptable day. |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
