Home > Maintenance & Mods (L322) > Painting Scuttle Panel - Advice Sought. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
Cant help with recommendations, but will follow this as I want to do mine |
8th Oct 2023 2:24pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
I used this trim restorer on mine a few years ago and surprisingly it is still black.
8th Oct 2023 4:16pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3729 |
http://www.fullfatrr.com/gallery/albums/us...C00622.JPG
8th Oct 2023 6:12pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8080 |
All I'll say is it will take less time to remove it than it does to mask it up, you will also get a better job done off the car. If you do do it on the car don't forget to put paper under the vent, inside the bonnet....
8th Oct 2023 8:31pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
As a model maker I wouldn't use the Humbrol enamels as I think it would spider Web crack on you. I can't recommend any other paint though. There's got to be something out there.... https://www.google.co.uk/search?q=aerosl+s...nt=gws-wiz visiting from www.rrsport.co.uk |
9th Oct 2023 6:04am |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 254 |
OK, thanks for the comments all. I have decided to take @nicedayforit's suggestion and give trim restorer one last try.
10th Oct 2023 1:36pm |
DanRRL322sc Member Since: 16 May 2022 Location: Bedfordshire Posts: 55 |
How did this work out? I too am fed up with the light grey/white plastic look that returns every 3-4 months after using plastic trim restorer on it! |
12th Jan 2024 10:27am |
Not done yet Dan. Life intervened. Will be done on the weather-acceptable day. |
12th Jan 2024 2:57pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2287 |
12th Jan 2024 5:24pm |
