![]() | Home > Technical (L322) > Front Window Reset |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7903 ![]() ![]() ![]() |
Ever since I’ve had this car sometimes when you auto close the front drivers window it will hit the seal and come back down as it thinks there is an obstruction. Not a massive issue in summer when the rubber is softer…. Normally I fix it by stopping and then closing the window with a bit of pressure from outside on the top front corner with my finger, and it shuts and seals fine…. Anyway… the garage had it yesterday to do CV gaiters and he opened the window when he was positioning the car on the lift, so he had issues closing it. He said when it was down he held the window switch for 15 seconds and it did some type of reset…
Cheers. It’s not the sunroof, had that issue last year 🤣. It’s def around the mirror area, or even down the door gap
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
Have you tried the reset trick open fully, press and hold for up, when it gets to the top and stops, let go and lift straight away for a couple of seconds you should hear a clunk/click.
