Home > Technical (L322) > Front Window Reset
mjdronfield
Front Window Reset
Ever since I’ve had this car sometimes when you auto close the front drivers window it will hit the seal and come back down as it thinks there is an obstruction. Not a massive issue in summer when the rubber is softer…. Normally I fix it by stopping and then closing the window with a bit of pressure from outside on the top front corner with my finger, and it shuts and seals fine…. Anyway… the garage had it yesterday to do CV gaiters and he opened the window when he was positioning the car on the lift, so he had issues closing it. He said when it was down he held the window switch for 15 seconds and it did some type of reset…
My issue now is there is bad wind noise round the window at anything over 30 mph. How can I make sure it’s fully shutting now? Can I shut it with my old trick and then hold the button up for however many seconds?
Of course the noise might not be that but it’s too much of a coincidence at this stage…
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #675056 7th Oct 2023 4:48pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
Close the window fully using the button to the first ‘point’ and test it at that at speed?? And then do the full ‘reset’ ie holding the button?? Also is the noise maybe the sunroof needing a reset too?? Shocked Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #675058 7th Oct 2023 5:25pm
mjdronfield
Cheers. It’s not the sunroof, had that issue last year 🤣. It’s def around the mirror area, or even down the door gap
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #675059 7th Oct 2023 5:40pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Have you tried the reset trick open fully, press and hold for up, when it gets to the top and stops, let go and lift straight away for a couple of seconds you should hear a clunk/click.
This normal when disconnection of the battery well it was for me. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #675060 7th Oct 2023 5:50pm
