![]() | Home > Maintenance & Mods (L322) > L322 2012 TDV8 4.4 Oil Cooler Issues |
Glenrands 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
Glenrands but ensure you tell Ross and Mike the complete back story as some places won’t work on issues that others places have failed to resolve. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
proxomos Member Since: 03 Jul 2023 Location: Bournemouth Posts: 9 ![]() ![]() ![]() |
"some places won’t work on issues that others places have failed to resolve"
Call and chat to them |
A typical repair will just involve replacing the seals on the oil cooler but the oil cooler can crack or warp meaning the problem will return. The consensus now is that it’s better to replace it given the work involved to get to it. 2012 TDV8 Vogue (L322) |
Thanks, i'll call Glenrands on Monday.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1197 ![]() ![]() ![]() |
When JLR did mine it took 4-5 flushes of the cooling system to clear the oil they did not replace the water pump.
Out of interest how much did they charge?
I'm not sure it was about 4 years ago somewhere in the region of £700 I think when I inquired about the job with an Indie there was a couple of hundred pounds in it.
Just been quoted £1650 to replace the oil cooler, reflush and new coolant bottle. Thats from an indy in Bournemouth, still waiting on JLR to come back to me. Gone:
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3194 ![]() ![]() |
If I were you, I would go to Steve at T & S Norman (https://www.tandsnorman.com), It is 50 miles/90 mins away from you; they are without a doubt the most knowledgable LR specialist there is (over 20 years' LR experience) and fixed mine where everyone else failed. He is a proper mechanic not a laptop jockey. He did mine for c. £1200. replaced all necessary items like coolant bottle, flush out etc.
glenney Member Since: 04 Jan 2021 Location: East Sussex Posts: 21 ![]() ![]() |
Can't go wrong with Glenrands. I've used them for the last 2 years and they've been great. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Sounds like the "specialist" you used was one of these who just like to call themselves that sad don't know the L322 whatsoever - there's many out there. 2015 Range Rover Autobiography 4.4 SDV8 |
So although the oil cooler was replaced using aftermarket parts its not leaking. The coolant system was reflushed 3 times and a smaill amount of oil came out. The coolant system is always under pressure even when cold. So a dye test was carried out and it came back positive.
