![]() | Home > Technical (L322) > range rover wont start |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 282 ![]() ![]() ![]() |
Check your battery condition and age; performance tends to fall off a cliff once they start to get old. If it needs replacing get a good quality AGM.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Ignition lock ? |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
“Intermittent wouldn’t start” as in…..turns over but won’t fire? Won’t turn over?
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 457 ![]() ![]() ![]() |
right wife called aa out as i was away....and they checked started alternator and battery which came up as bad (79%) which i have to admit is a surprise as its only about 18 months old replaced by last owner(yuasa hsb019) .....i was thinking it was something to do with the ignition.....@ fox889 key turns but just wouldn't fire steering wheel not locked moves freely.aa jumped started it .
been looking for a new battery and cant make my mind up between
Got a funny feeling if you go for the 020 you’ll have to trim the battery corner or similar. Very tight fit an 020, 019 slip in lovely😂🫣 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
I could be wrong, but a 2008 MY should be able to just squeeze an 020 in without having to faff about cutting off bits of battery casing. My 2006 does easily. Later years use AGM batteries and have extra cabling in the way. Previous cars:
An 020 will fit fine but you need to get creative with the positive terminal as the starter fuse block won't fit... |
yea ive been reading about the fit ............hmmm i dont know |
Super Sloth Member Since: 23 Jun 2020 Location: Derbyshire Posts: 25 ![]() ![]() |
Run a jump lead between engine and negative terminal on the battery. This will hopefully rule out a dodgy earth lead. |
Stick an 019 in with no dramas then, that’s what was in there from new. Tayna is the best source. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice! Alfa Romeo Giulietta Just one Montesa now, 349 White Wonder Austin A40 Farina MK2 1975 Morris Marina 1.8TC 1973 Honda CB250 K4 |
Yea may go with the 19 ……still pretty new to the Range Rover community,would I be right in thinking that a low/ bad battery would show a lot of error codes when using my gap tool.? |
@ super sloth …..it’s up and running now so would it still work with the jump lead ? |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
A poor battery will result in lots of error codes…replacing/ recharging the existing battery is invariably the first thing you should do. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
