Home > Maintenance & Mods (L405) > which oil
Phoenix
Have you done the 'full' reset? not just the 'I've changed the oil' reset? You need to do the oil level reset (hold for 5 seconds) to establish the baseline.
Post #674715 1st Oct 2023 7:24pm
V8Russ
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I did the bonnet and driver door open with ignition on and brake/eccelorater pedals down for 30 seconds.
Is that what you mean?
Post #674717 1st Oct 2023 7:28pm
Phoenix
That's just the service interval reset, not the oil level reset.
https://www.fullfatrr.com/gallery/albums/u...ILLING.pdf
Step 10 onwards.
Post #674724 1st Oct 2023 7:51pm
V8Russ
Thank you for the info. I'll set it up after getting up to temp.
Also is it normal for high pitch sound from the engine bay after switching off the ignition and locking the car? If no what can this be?
Post #674725 1st Oct 2023 8:05pm
Phoenix
Could be turbo / EGR doing their end-to end clean/calibration sweep, without hearing it I can't be 100% but those components do move on shutdown.
Post #674727 1st Oct 2023 8:21pm
