Home > General (L405) > L405 SDV8 life expectancy / reliability
nrgltd
I have a 2016 SDV8 Vogue which has 58k miles on it, has been utterly reliable and has only been (badly) serviced by LR twice. Used a v.good inde since.
I’m in a quandary as I now have a new replacement 460 but the 405 is so good that I hate to part with it. Our previous TDV8 lasted 10 years with almost zero problems.
Is there any info anywhere ref longer term reliability issues or would readers be able to offer me advice - good and bad - please? My intention would be to use it for occasional jaunts into Deep South of Ireland which are 1000miles return from northern Scotland.
Any advice welcome and gratefully received.
Post #674574 30th Sep 2023 9:55am
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
My 2016 MY VSE has 60K on it and like yours has been utterly reliable, no issues at all, just preventative maintenance done with a good local MD. I usually swap out of cars at 3-4 years, but I’m intending to keep this one a while longer because its such a good car. Keeping yours seems to be a no brainer to me.
Post #674583 30th Sep 2023 1:55pm
I'd have kept the L405. Except now you've bought the L460, I'm not sure what the point would be..... why did you feel the need for the change & is that still true ?
Post #674586 30th Sep 2023 2:46pm
nrgltd
When LR finally announced a decent electric range PHEV - the 460 - I just had to have one. The one I have isn’t the one I ordered but a cancelled car which for some reason I was offered at list. The one I ordered apparently arrives in Jan ‘24 so really don’t know what to do now !!! It’s also been upgraded to 550e and mucho dinero more.
The idea was to keep the SD as the shorter distance UK only car and the new one for our long journeys. LR made me sign a one year clause whereby I can’t sell the present 460 (a 440e HSE) until end of Jan ‘24 so there’s an option to sell. However the other half now loves it and selling it could cause a problem. 😎
One will have to go. Watch this space.
Post #674591 30th Sep 2023 4:26pm
SDV8 isn't a great for short journeys only - depending on how you define short.....
Post #674596 30th Sep 2023 6:14pm
Super Sloth
Average life expectancy of a car in the uk is around 14 years / 200k.
I suspect you’ll be ok for a while!
Post #674700 1st Oct 2023 7:47pm
Stick Legs
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
2015 SDV8, 87000 miles, no issues.
If it doesn't make 200k I'll be miffed frankly.
If it does die then I'll be looking at a very late L405 in Byron Blue & Ivory to replace it.
Ideally another SDV8 or maybe an SC Petrol, but in anycase a FFRR should have a V8 in it.
I drove the L460 P350 with the straight six and it felt lovely...
...but V8.
I am a child.
Post #681576 31st Dec 2023 3:50pm
Vogue
I’m on my 3rd V8 Diesel - all have been faultless and no DPF issues either - I average 9/10k miles a year 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #681585 31st Dec 2023 5:47pm
tomo141
My L405 V8 MY18 failed with 25000 miles. LR MD's couldn't get to the bottom of it miss firing. Can't fault LR warranty they spent a fortune on it. It eventually failed catastrophically and needed a new engine. LR no longer do the 4.4 V8 diesel, if they did they would have put a new engine in under warranty. 6 months of pain and JLR UK had to buy it because they couldn't fix it.
My L405 V6 3.0 didn't have one warranty job in 4 years, I really wish id kept it.
I have tried literally every other make and nothing compares to a RR.
Broken man right here.. Big Cry ------------------------------------------
L460 D350 73 24 model FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #682713 14th Jan 2024 6:12pm
ott
Estonia 2018 Range Rover Autobiography SDV8 Aruba
My 2018 V8 diesel spun rod bearing after 42 k. miles and engine was toast. It was under warranty, but as replacement engines are not available its write off. Serviced as required by main dealer and mostly highway miles.
Post #683581 22nd Jan 2024 8:55pm
tomo141
Mine was like new, can't believe they wrote it off. I'm not sure if we will ever see the 4.4 V8 produced again.
I can't find another example as good as what i had, I wish I had kept it and paid to have the engine rebuilt myself. I was quoted 17k for rebuild.
I got a good deal on a new X5 M50i which is loaded with lots of extras, comfort pack tec pac etc..
It's ok and sounds great, but its not a RR. I put a deposit on an SV then backed out as i had lost confidence in the brand.
Im probably going to sit it out and wait for the 460 4.4 AB which is same engine as my X5. They are dropping in price fast. ------------------------------------------
Post #683736 24th Jan 2024 12:08am
ott
Funny that previous to L405 I did run Disco 4 and it was faultless for almoust 100 k. miles despite having V6 diesel engine.
After I lost my L405, also went with latest 3 l. diesel-hybrid X5. Its lighter, bit faster and has better handling, but doesn't provide sense of occasion like FFRR. I like new RR Sport, but not sure I want to go back to brand which is unable to support its products with spare parts.
Post #683742 24th Jan 2024 8:33am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I've had my 7 year old L405 SDV8 dealer bought for 2 years now and it had/has several faults in that time even though its supposed to be a low mileage 54k car.
It came with an oil leak and the oil cooler has been replaced.
The ancillary heater pump doesn't work and still doesn't work.
It came with very low refrigerant but I topped that off and it seems OK now.
It has a noise over bumps so I'm thinking the front drop links may be worn.
It occasionally goes into limp mode with air flow errors, new MAF sensors hasn't cured it.
The inlet side is heavily coked up which isn't unusual with these cars
Other than that, fantastic. I do prefer my old TDV8 L322 that I traded in for the L405, apart from the road tax.
Post #683891 25th Jan 2024 6:53pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Still going strong after 6 1/2 years. I’ll run it for many years yet 👍
Post #686333 24th Feb 2024 10:51am
