Home > Technical (L322) > air suspension,steering angle |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
Could be the Steering angle sensor. It tells the ECU which direction/position the steering wheel is in.
29th Sep 2023 12:00pm |
rover75lover Member Since: 02 Aug 2021 Location: wales Posts: 13 |
hi all ,
1st Oct 2023 4:13pm |
No idea really, might be a slight leaky bag at the front but unusual if its both side at the same time.
2nd Oct 2023 10:03am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8184 |
With those lights on you have a "hard fault" with the EAS, you need someone with the correct diagnostics to reset it, you can't do it without even if you fix the issue.... Pete
2nd Oct 2023 10:09am |
