![]() | Home > Technical (L405) > FBH Remote |
I've got one spare, £30 |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 500 ![]() ![]() ![]() |
If the OP doesnt have it Phoenix I def will.
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 59 ![]() ![]() ![]() |
I’ve sent you a PM. Thx |
is it possible to use these with the Webasto app on a phone? I cant quite access to QR code on the side of the heater unit as there are wires in the way and its an awkward angle, I tried putting in a serial number that is next to it but nowt happens. First time FFRR owner |
Earlier L405's were fitted with Eberspacher units, the remotes are not cross-compatible.
mine is def webasto, I can see that on the sticker, that will explain why the fob doesnt work.
Payment has been sent so unfortunately you need to look elsewhere - Duckworths will give you a 20% discount on list. |
no dramas Phoenix, thanks for the update, I've just dropped on one from eBay, a bit more expensive than yours but not complaining. First time FFRR owner |
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 92 ![]() ![]() ![]() |
just use the in control app, it is much better and has other useful features. 2016 AB SDV8 Barolo black |
I cant as it starts the engine and the immobiliser wont let it. First time FFRR owner |
But the FBH doesn't need to have the engine running.. |
the remote app starts the main engine, (it did on mine before the immobiliser was fitted) not the FBH, if you can steer me to where it starts the FBH I'd be a happy man |
My car is a 2016 so it could be different.
