Home > Off Topic - Other Cars > Clunking from osf suspension over undulations/bumps
garyRR
The car is a Passat.
The front right suspension clunks over undulations/bumps in the road surface.
I've done a check of the ball joints and all seem ok.
I've also taken a video of steering lock / Rock test: ?si=KFKr5rud2l03hfGA
I've also bounced the suspension up and down and got no noises. I did note that when jacked up, the dust boot is loose, but when holding under its own weight, it does press into the top.
Any ideas of the cause? I note the ticking sound which could signal the CV joint, but would this clunk? 2015 Range Rover Autobiography 4.4 SDV8
Post #673162 11th Sep 2023 9:00pm
JayGee
Try putting you hand nr components when the steering is being turned as you will feel any binding. 2012 TDV8 Vogue (L322)
Post #673183 12th Sep 2023 9:45am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
ARB drop links maybe?
Post #674122 24th Sep 2023 10:22am
Deleted
Post #674126 24th Sep 2023 11:55am
garyRR
I figured it out in the end. The bearings gone inside the shock absorber. 2015 Range Rover Autobiography 4.4 SDV8
Post #674134 24th Sep 2023 2:10pm
