Clunking from osf suspension over undulations/bumps | |
The car is a Passat.
The front right suspension clunks over undulations/bumps in the road surface.
I've done a check of the ball joints and all seem ok.
I've also taken a video of steering lock / Rock test: ?si=KFKr5rud2l03hfGA
I've also bounced the suspension up and down and got no noises. I did note that when jacked up, the dust boot is loose, but when holding under its own weight, it does press into the top.
Any ideas of the cause? I note the ticking sound which could signal the CV joint, but would this clunk? 2015 Range Rover Autobiography 4.4 SDV8
