![]() | Home > Technical (L322) > Oil analysis after a 'service required' message |
jtq4u Member Since: 23 Aug 2023 Location: Portsmouth Posts: 37 ![]() ![]() ![]() |
Given that we know my oil is at the edge of ruined by oil dilution it might be interesting to do a home, low tech, measure of its viscosity as a bench mark.
From a scientific viewpoint.......;
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
I’m a PhD level scientist and work in the oil industry around spill response and deal with viscosity changes etc all the time when oil and water interact. Take it from me, don’t waste your time and get it looked at as per previous posts is my advice |
Very true, any home experiment that found the oil to have lowered in viscosity doesn't prove that lowering is because of fuel dilution. It would be like counting corpses in a mortuary to decide the number of covid deaths. However.. the fact there is a lowering of viscosity means you need to change your oil regardless of the cause, so perhaps it doesn't matter. If I could tally a 'flow time' to mean the oil has reached 8 cSt (minimum acceptable viscosity).. then it doesn't really matter if it was the diesel that was the culprit. Scientifically they are going to be able to tell me at the lab (when they retest) if diesel was the cause, as they use machine induced chromatography which will separate the diesel back out. Life may be too short to bother however.. my main finding that matters is that the Range Rovers 'Service Required' indictator is in fact correct. Thats what I really wanted to know ![]() Last edited by jtq4u on 22nd Sep 2023 12:58pm. Edited 1 time in total |
Ah Rob, you're the same guy I've chatted to on Facebook with the dream job driving around on the Motor boat, lucky thing that you are ![]() Yeah I am going to get the high pressure side of the turbo pipework tested. I am just looking to find a place or way to do so without breaking the bank. I emailed the company recommended on the other forum but they didn't provide a quote just said they would be happy to take it in for investigations. With workshop charges at north of 100 quid an hour these days I am not up for that sort of unbounded task! My father in law is asking at his friends Landrover specialist workshop whether they have a high pressure smoke tester. If they do then I will get it tested when I am next in Devon, next month. |
You are so very lucky to have Glenrands just up the road - I'd book it in without delay rather than waiting a month esp with the metalic contamination after just 3k miles. 2012 TDV8 Vogue (L322) |
Amazingly the lab do keep the samples for a period of time after giving the results back it seems (perhaps in case of complaints!). They have now tested my sample to establish the amount of diesel that was in it and found it to be less than 2%. So actually the viscosity change is potentially not because of the regens. The RR must just be psychic in feeling it needs an oil change. I wonder what really thinned out the oil. Perhaps Westway oil is just ![]() ![]() |
Keep us posted and maybe meet in person soon |
