Home > Technical (L322) > Oil analysis after a 'service required' message
jtq4u
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Hi all,
I got a 'service required' message last week after just 3,000 miles on the oil.
This is likely related to the battles I have been having with the DPF.
Anyhow I wanted to know how truthful the car's opinion was on needing an oil change so I took the plunge and paid for an oil analysis.
I attach it in case anyone is interested.
It says it is a negative for Fuel dilution. However it also shows that my oil is out of specification slightly.. it is around a 0W25 oil now, after 3000 miles. Of course we don't know how accurate the Westway 0W30 oil was in the first place.
It probably isn't far enough out of spec to require the oil change right now
If I had an infinite amount of money I would test:
- some brand new Westway oil
- Some oil with a deliberate 7% diesel mixed in (to see if the test center notices it)
- Some oil at the end of a full year's use.
Post #673975 21st Sep 2023 3:13pm
JayGee
I'd either take this up with Westway or choose a different oil ( or both). Have you had excessive oil use or smoke from the 2nd turbo? How much was the oil analysis BTW? 2012 TDV8 Vogue (L322)
Post #673979 21st Sep 2023 3:32pm
jtq4u
I don't think I can immediately blame westway, as I don't know for sure if the oil analysis company is right in saying there is no fuel dilution.
If there was oil in the fuel it would have reduced the viscosity. To be sure I'd have had to send some brand new oil to them for analysis. But of course that would then double my cost Wink
cost of the analysis was £37.80 from aaoil.co.uk
I guess I might not see any smoke, because the DPF would capture it I think?
I do still have on my to-do list performing a high pressure leak test post turbo. I just need to find somewhere local and reasonably priced.. or make up a piece of kit myself.
Post #673986 21st Sep 2023 4:25pm
JayGee
I think it's safe to assume the oil analysis company can tell if there is fuel in the oil - why would you think they can't if they can do everything else. The DPF captures soot ( particles of carbon) and the 'smoke' from the 2nd turbo is actually oil vapour so it easily passes through the dpf 2012 TDV8 Vogue (L322)
Post #673987 21st Sep 2023 4:34pm
jtq4u
Fair point about the oil analysis company I guess.
I wonder how quickly oil normally changes from its original viscosity - I have no idea!
The fact they have flagged it up suggests it is significant. Maybe I should ask westway what their oil starts off at. As I said, if I had the money and inclination I'd send some new oil for testing.
No oil/smoke coming out the exhaust. Always nice and invisible.
James
Post #673988 21st Sep 2023 4:59pm
JayGee
It should hold it's viscosity. It gets thicker as the soot load increases and thinner as the fuel contaminates it so there is some kind of equilibrium. I'd maybe be slightly concerned with the iron content as a thinner than stock oil may not provide the correct separation of moving parts esp on a high mileage engine where it's sometimes beneficial to run a slightly thicker oil. 2012 TDV8 Vogue (L322)
Post #673989 21st Sep 2023 5:03pm
garyRR
Your DPF issues - I trust you've followed all the usual causes:
- 2x charge hoses
- 4x donut hoses
- throttle body seal
- smoke test for intake leaks/cracks
- drive the car on the M27 once a week
...also, did the garage forget to reset your service interval? This sounds like the most likely cause of the message to me.
Grade of oil used or specification or oil used I'd also question. 2015 Range Rover Autobiography 4.4 SDV8
Post #674008 22nd Sep 2023 6:51am
garyRR
- 2x charge hoses
- 4x donut hoses
Post #674009 22nd Sep 2023 7:08am
jtq4u
As it turns out it wasn't so safe after all Wink
The uk analysis company outsources the lab work to a UK company, and then the production of meaningful results to a US company. I found the bloke in the US who actually wrote my oil report and he has said that the UK company wrongly tested for petrol in the oil instead of diesel.
He also said that therefor the likelihood is that both the reduction in viscosity and the iron levels are down to diesel fuel dilution. I will of course be following up with a complaint to the company who took my money.
Post #674014 22nd Sep 2023 8:41am
jtq4u
- 2x charge hoses
- 4x donut hoses
I have visually inspected everything, but not yet had a high pressure smoke test, as I need to find someone local and reasonable in price to do it. I may get round to making a piece of kit myself, and doing it (but the wife generally has less interesting things to assign to my time!).
Sadly most of the driving is already on the M27! probably 70% of it is at 50 to 70 mph.
last week I did 120 miles to work and back >50mph. I started at 0g soot and finished at 17g soot (and a request for regen.. too late of course as I have now finished my trips on the motor way for the week).
I reset the service data after changing the oil back in May.. 3000 miles ago. But as we now know the car is right to be requesting an oil change most likely.
Post #674015 22nd Sep 2023 8:45am
JayGee
Glenrands is just up the A3 from you. Suggest you book it in and they will sort it for you 2012 TDV8 Vogue (L322)
Post #674017 22nd Sep 2023 8:59am
DrRob
Ditto that. Drop it off with Ross and the lads. They have a smoke tester and full LR main dealer level diagnostics and excellent technicians. Tell them I sent you Whistle
Mine is there currently have a new air con rad, lower front arms and a small oil leak investigated...
They do loan cars... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #674018 22nd Sep 2023 9:02am
jtq4u
As someone with a scientific background I decided there must be a way to calculate the viscosity of a blend of two liquids and it turns out there is of course.
So I have done the calculations for what a liquid made up of 93% oil and 7% diesel is.
The answer is 8.0 cSt
so my oil is very close to 7% oil dilution
(range rover's max acceptable value for that year.. they did, for better or for worse recode it to 10% I think in later years - probably just to stop people complaining about oil changes, rather than for it being OK).
if you want your mind blown, or love maths.. here are my workings to check
https://citizendium.org/wiki/Liquid_viscos...%20(loge).
VBN = 14.534 × ln[ln(v + 0.8)] + 10.975
VBNBlend = [wA × VBNA] + [wB × VBNB]
            e(VBN - 10.975) ÷ 14.534
v blend = e^                            − 0.8
https://www.researchgate.net/publication/35461426_Fuel-Lubricant_Interactions_Critical_Review_of_Recent_Work
shows the viscocity of diesel at 100 degrees is 1.28 cSt
the lowest acceptable viscocity of 5W30 oil is 9.77 cSt
lets put the values into the equation at 7% dilution:
VBA = 14.534 × ln[ln(9.77 + 0.8)] + 10.975
VBA = 14.534 × ln[2.358] + 10.975
VBA = 14.534 × 0.8578 + 10.975
VBA = 12.468 + 10.975
VBA = 23.4426              23.442587839924595639895981511893
VBB = 14.534 × ln[ln(2.08)] + 10.975 =
VBB = 14.534 × ln[0.7324] + 10.975 =
VBB = 14.534 × -0.3115 + 10.975 =
VBB = -4.527 + 10.975
VBB = 6.4481              6.4480615302417669052839795265684
VBNBlend = [0.93 × VBA] + [0.07 × VBB]
VBNBlend = [0.93 × 23.4426] + [0.07 × 6.4481]
VBNBlend = [21.8016] + [0.4514]
VBNBlend = 22.2530
      e((VBN - 10.975) ÷ 14.534)
v = e^                            − 0.8
      e((22.2530 - 10.975) ÷ 14.534)
v = e^                               − 0.8
      e(11.2780 ÷ 14.534)
v = e^                            − 0.8
      e(0.7760)
v = e^                            − 0.8
      2.1727
v = e^                            − 0.8
v = 8.781981486777                    − 0.8
v= 7.982
so a viscosity of 8.0 relates to an oil dilution of 7%
Post #674019 22nd Sep 2023 9:11am
jtq4u
Cool, thanks for the reference, I'll get in contact with them and see how much they charge for a smoke test.
I'll also ask if my father in laws friend who works at a land rover specialist in east devon does such tests. He might of course charge my favorite price of 'free' Wink
Post #674020 22nd Sep 2023 9:14am
JayGee
You need also to factor in the soot content and it's viscosity increase 2012 TDV8 Vogue (L322)
Post #674022 22nd Sep 2023 9:58am
