Home > Maintenance & Mods (L405) > Air con suddenly stopped blowing cold |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 136 |
I doubt Halfords are AC experts. That's a safe assumption seeing they said you had no leak but you clearly have a leak. The problem with cars like the RR is they have front and rear AC so some very long pipe runs under the drivers seats and back which no amount of dye would ever detect. All dye is any good for is what is happening in the engine bay with the service port valves, hoses, compressor seals and condenser, which would probably cover 95% of leaks.
3rd Aug 2023 3:53pm |
Norman.D.Seagull Member Since: 20 Dec 2022 Location: Lymington, Hampshire Posts: 14 |
Thank you for responding - much appreciated. Yes I am learning how complicated this AC is particularly with the cooled seats feature and it is booked in with my local RR expert . He seems to know what to look for but cant fit in in for 10 days. I will check if he has a sniffer and if not I have seen one on e-bay and will get that.
3rd Aug 2023 4:30pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Who are you using nr Lymington? New Forest in Cadnam? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
4th Aug 2023 11:31am |
Having hunted around for a good RR mechanical engineer and not a fitter I found/was recommended a chap called Ben Broomfield ,Carbetta ,Unit 6 Sway Ind Park , Sway , 01590 683037 info@carbetta.co.uk .
5th Aug 2023 8:27am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
Just for your information the cooled seats run on a peltier system and are not connected to the cars air con... Good luck with your fix... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
5th Aug 2023 9:25am |
Thanks for that information - just looked that up - 'Semi conductor doped Bismuth Tellulide' . For a moment I was on the bridge of the Star Ship Enterprise with Dilitium Crystals breaking down !
5th Aug 2023 9:48am |
It's all done by "smoke and mirrors".... Pete
5th Aug 2023 10:22am |
Just an update on my non cooling Air-con,
18th Sep 2023 3:49pm |
If the refill gas used is actual R1234yf and not the cheap hydrocarbon 'alternative' then the price charged is very reasonable for a 1kg recharge. You can safely assume JLR would be closer to £250 for the gas charge alone.
20th Sep 2023 9:47am |
