Home > Technical (L405) > Sdv8 acceleration issue |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
Check the turbo actuators move freely. |
19th Sep 2023 11:32am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Does it have the extra section of wiring harness that fits between the block and the original wiring connector? The harness is supposed to prevent oil migration from the sump along the wires to the turbo electronics. N375 is the code for the service bulletin to fit the short harness.
19th Sep 2023 12:34pm |
DESCAT ANDRE Member Since: 18 Sep 2023 Location: Bordeaux Posts: 8 |
Thank you very much for this response. This actuator problem is known on this forum. I called the garage. The workshop manager told me that to check if the actuator is moving correctly, you have to take out the turbo. Do you think he's right? |
19th Sep 2023 3:01pm |
Hello and thank you for your message. I have seen posts on this forum for wiring problems and oil leaking on the electronics. This is not easy to translate into French. I will ask for the fault code and I will give it to you (it seems to me that the garage told me that the fault code is turbo solenoid) They put smoke in the intake and there is no leak. Today they sent the file to land rover Europe service for complicated faults, so we are waiting for a response. The car is in a Land Rover dealership. Thanks again and I hope to give you some information soon. Sincerely, Andrew |
19th Sep 2023 3:08pm |
The default code is P004D-77
19th Sep 2023 4:20pm |
Good evening, I made a mistake in my first message last year, and for the same fault code, the Land Rover garage changed the LH turbo (i.e. driver's side for the French) |
19th Sep 2023 7:03pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1199 |
Check these out
19th Sep 2023 7:08pm |
Last year, before we changed the LH turbo :codes were:
19th Sep 2023 7:09pm |
Thank you +++ |
19th Sep 2023 7:13pm |
Good morning,
27th Sep 2023 5:39am |
