![]() | Home > Technical (L322) > Ride gets firmer after 3-4 hours then smooth the next day. |
Here is the theory - when new the shocks are filled with pressurised nitrogen to prevent gas bubbles appearing in the oil as the shock is working. If this leaks out over time then the shocks will loose effectiveness as they are used on a journey and feel harsh and crashy. The rears are cheap enough and easy to do so may be worth a try - how many miles on them? 2012 TDV8 Vogue (L322) |
Floopy Member Since: 28 Jan 2023 Location: Chichester Posts: 81 ![]() ![]() |
Thanks mate, that makes sense.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1415 ![]() ![]() |
Agreed, as the damper fluid is worked through the damper valve it heats up and this can cause issues with thermal expansion which creates stiction and harshness.
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 ![]() ![]() ![]() |
Be interested to see if you get any improvement from this. You've got the same symptoms that quite a few of us have been complaining about here: https://www.fullfatrr.com/forum/topic59154.html and here: https://www.fullfatrr.com/forum/topic66429.html However, most of the above are on the VDS / variable damper equipped cars (09-12), so it's interesting that yours is on an earlier car. Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw Home of the 'Cheapest 4.4 TDV8 Range Rover" |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I had this so changed the hub bushes and front and rear shocks and bags as well as wheel bearings and it improved but not a great deal so changed the rear subframe bushes which I did about 5 years ago and 100k miles ish now the rear subframe bushes showed little wear with a big pry bar but when \i took them out they were knackered inside anyway after changing them did a run to Bordeaux and it was a different car and no nasty crashing so I think it is not one thing but a bit of everything the shocks may be on their way out and it is amplified by the other worn bushes
