Home > Technical (L322) > 4.4 TDV8 Rear Propshaft, can it be disassembled? |
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 55 |
Just replaced my rear prop for an oe GKN part. The centre bearings available do not appear to be of good quality.
21st Mar 2021 12:35pm |
Geoff Hurst Member Since: 09 Oct 2021 Location: Sourhampton Posts: 10 |
I’m currently in the same boat which still doesn’t have a paddle! All advice gained is along lines of best to replace complete than fanny around, always seems to be the default answer. |
11th Dec 2021 9:02am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The 4.4 TDV8 Propshaft is a two piece assembly and can be split easily (held together with a single bolt at the centre joint) so it's easy to replace just the bearing. Just make sure you get a genuine LR bearing and not an aftermarket one, as they're not as good as the original LR parts. |
15th Dec 2021 6:28pm |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 |
Hi just took rear prop shaft of to replace centre bearing. No number for just bearing from landrover so ordered cheap one and will relace the bearing with good quality, well that is the plan . have removed the shaft assembly and loosened the bolt inside centre joint but several taps and the two shaft don't seem to want to part company is the a knack or is is just rusty tighty. |
25th Sep 2023 2:16pm |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 63 |
It's most likely a standard metric bearing. Take the old bearing along to your local SKF, FAG or Timken vendor, and they can very likely sort you out with an OEM quality bearing at a fraction of what LR would charge.
26th Sep 2023 4:47pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
More often than not it’s the rubber bushing around the bearing that fails rather then the bearing itself.
26th Sep 2023 7:44pm |
