Home > Maintenance & Mods (L405) > AC only cold on passenger side
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi all had my air con re gassed at ATS last month as it was running warm no cold air lads said it was really low so re gassed all good but today only cold air from passenger side and warm from driver side any ideas as I would of thought if there was a leak etc… it would be warm from both sides not just one. Here are pressures read from IID Tool when AC is off when the AC was on it went to 900 KPA.
 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #673723 18th Sep 2023 6:09pm
Classic sign of low gas, cold one side, hot the other, I guess you have a minor leak which is taking a long time to all leak out.... Thumbs Up Pete
Post #673747 18th Sep 2023 10:10pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
That pressure is a fraction on the low side, at an ambient of around 17C you should be around 950-1000kPa with the compressor running. However, its not too low that you should have temperature differential across the front. That is usually indicative of a failed blend door motor. That is quite a common issue and usually it is the drivers side that goes first, being the one that gets most use. It's not a massively hard job to change the actuators yourself.
If you have a decent scan tool it'll give you the blend door actuator position from the AC module readout. If changing the temperature dial doesn't change the door position then you know that is your issue.
Post #673890 20th Sep 2023 9:56am
jaysta10k
Thanks for this bit of guidance really appreciate it. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #673921 20th Sep 2023 3:28pm
