![]() | Home > Maintenance & Mods (L405) > AC only cold on passenger side |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
Classic sign of low gas, cold one side, hot the other, I guess you have a minor leak which is taking a long time to all leak out.... |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 150 ![]() ![]() ![]() |
That pressure is a fraction on the low side, at an ambient of around 17C you should be around 950-1000kPa with the compressor running. However, its not too low that you should have temperature differential across the front. That is usually indicative of a failed blend door motor. That is quite a common issue and usually it is the drivers side that goes first, being the one that gets most use. It's not a massively hard job to change the actuators yourself.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Thanks for this bit of guidance really appreciate it. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
