![]() | Home > Maintenance & Mods (L322) > Best source for discs, pads and service items |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4326 ![]() ![]() ![]() |
We have a site sponsor https://www.advancedfactors.co.uk/ or Duckworths
OEM are Brembo disks and Jurid pads which are not cheap even from indy suppliers. Also depending on your level of ability changing the front disks and pads can be a nightmare as the retaining pins and bleed nipples easily seize in the alloy calliper body. Piston seizure on the rears is also common so you may need new ones or a recon kit. If you download the workshop manual from the Wiki it will have a service section but if the car is new to you and you want to do everythig;
Bodsy for a gearbox Megaflush, transfer box and diffs
joel-h Member Since: 23 Sep 2018 Location: Kent Posts: 35 ![]() ![]() ![]() |
Brilliant, thanks everyone.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 463 ![]() ![]() ![]() |
@jaygee
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1792 ![]() ![]() |
Make friends with your local independent specialist. They'll keep most parts in stock, and advise brands/procedures where possible |
