Home > Maintenance & Mods (L322) > Best source for discs, pads and service items |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
We have a site sponsor https://www.advancedfactors.co.uk/ or Duckworths
12th Sep 2023 6:28am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3207 |
OEM are Brembo disks and Jurid pads which are not cheap even from indy suppliers. Also depending on your level of ability changing the front disks and pads can be a nightmare as the retaining pins and bleed nipples easily seize in the alloy calliper body. Piston seizure on the rears is also common so you may need new ones or a recon kit. If you download the workshop manual from the Wiki it will have a service section but if the car is new to you and you want to do everythig;
12th Sep 2023 7:39am |
Bodsy for a gearbox Megaflush, transfer box and diffs
12th Sep 2023 8:59am |
joel-h Member Since: 23 Sep 2018 Location: Kent Posts: 35 |
Brilliant, thanks everyone.
18th Sep 2023 11:05am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 404 |
@jaygee
18th Sep 2023 11:45am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
Make friends with your local independent specialist. They'll keep most parts in stock, and advise brands/procedures where possible |
18th Sep 2023 12:04pm |
