![]() | Home > Maintenance & Mods (L322) > TD6 Gearbox - Problem or not? |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
This is supposedly normal and the BMW diesel X5's are well documented in the forums for suffering it with even owners selling their X5's over it |
iowdave Member Since: 03 May 2011 Location: isle of wight Posts: 38 ![]() ![]() ![]() |
hi steven i have the same gearbox but i dont have this problem.. but there are more members on here better to advise you.my input is mine dont kick in any gear or any speed. |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 ![]() ![]() ![]() |
Start budgeting for a new gearbox. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3788 ![]() ![]() |
I think its a characteristic of the gearbox, especially after being in slow moving traffic, maybe its excessive drive fluid pressure or something, but after being in traffic, I used to get a clunk on take up, not sure if it was between 1 and 2 or 2 and 3. I wouldn't worrry about it unless you have got far worse symptoms |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
I get something similar in my TDV8 TBH, Range Rovers since the dawn of time have had transmission clunk so I just accept it and try to adjust the way I drive to make it less noticeable if I can.
Hi Steven,
Actually this is not the case - especially for the GM 5l40E in the TD6. Not all late model transmission fluids are the same and more modern manufacturing tolerances, materials, and construction make it increasingly important to use the proper fluid. This is why the ZF 5HP24 used in the V8 vehicles uses Esso LT71141 (not Texaco) whereas the TD6 uses Texaco ETL-7045E rather than both using a generic Dexron III, IV, or + ATF. BMW even specifies 2 different types of fluid in two versions of the 5l40E used in the X5: Texaco ETL-7045E in the BMW A5S360R and Texaco ETL-8072B in the uprated BMW A5S390R (thanks Bemble!). I did considerable research on this transmission and spoke to all sorts of people from Ian Ashcroft, to John Mackey, to some very competent folks at Sonnax Transmissions. The 5l40E has some very real problems - nearly all of which are pressure related. In a nutshell, the biggest wear issues stem from wear in the valve body bores and in the torque converter clutch valve bore. It seems that, for whatever reason, the aluminum used by GM in the casting of these pieces is softer than the material used in other (older) GM transmissions. This wear leads to improper shift/lock-up pressures which in turn leads to premature wear in the rest of the transmission components (which drop particulates into the fluid and exacerbate the wear in the valve bores) and, at some point, transmission failure. All of the people I spoke to concurred on a number of items: -'sealed for life' is not a good thing.As the filter is on the suction side of the system, it can't be made too fine as otherwise it would cause cavitation in the pump. These means that wear causing particulates, once in the transmission fluid, are there to cause damage till removed - or transmission failure. Early, regular fluid changes are good and necessary. - using the proper transmission fluid is vital. The valves tend to oscillate relatively rapidly in their bores and the GM engineers put considerable effort into the interaction of the materials vs. pressures vs. wear problems. Use only the recommended fluid - not all fluid is alike. - when transmissions are rebuilt, cleanliness is vital as is checking the tolerances in the valves and the pump - after a rebuild, changing the fluid is almost more necessary than before to reduce the likelihood of a repeat failure Most TD6 transmissions will fail at between 80-100k miles. Some of the rebuilders I spoke to told me that they make minor modifications such as sleeving the valve bores with a harder material and for this reason, they felt that a transmission rebuilt properly was actually better than ex-factory while other stated that the best one could hope for is back to OEM-spec (with another failure in 80-100k miles). I would not go to the dealer to buy my transmission fluid, but I would purchase only the recommended Texaco ETL 7045E for a TD6. Anything else is penny wise and dollar foolish IMO. I've since spoken to an engineer with Texaco (by chance) and asked about this issue. His reply was that while ETL 7045 was in no way superior to other Dexron III ATF but that the detergent composition might be what makes the difference. So, advice still stands. Just don't buy from the dealer. I found ETL 7045 locally for under €7/L. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 ![]() ![]() |
Thanks everyone for your input.
Hi Steven,
Thanks Steve.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
does anyone know where the gearbox control module is fitted on the FF? Current: TDV8 (3.6) RRS HSE
Under the bonnet on the drivers side in the box with the rest of the electronics |
thanks for that.. |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
Tourque converter this is the cause of all gearbox problems replace and flush also check input shaft they wear too |
the BMW X5 has similar problems to the TD6, the torque convertors go at about 50k, this was a known problem on the earlier cars. BMW knew about it but tended to do nothing. it would break down quicker if you used the car to tow with!!
