Home > Maintenance & Mods (L322) > TD6 Gearbox - Problem or not?
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
Isn't it the valve body , with the soft castings and wear issues causing debris to enter the T/C and that what causes the failure? So unless you replace the valve body the issues will return.
Post #80367 11th Sep 2011 11:15am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Well my gearbox has just failed, using a local company to rebuild and will be making enquiries as to sorting out the valve block weakness, sleaving etc
Post #80368 11th Sep 2011 11:27am
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
Speak to Jeremy Fearn, (google him)
He can put you in touch with someone who builds upgraded gearboxes, that don't break.
Post #80369 11th Sep 2011 11:39am
