Thanks for following up on the issue. And glad they sorted the column adjustment, at least.
So you still seem unsure whether they Vin-Coded the newly installed sensor or not; I would encourage you to have them clarify that to you. It may be something that simple.
You may also be able to carry that out with the IID tool but have a look at the manual as I'm not 100% sure.
I've had a similar experience with "expert" ECU workshop who claimed to be able to repair my ABS module (common failure on earlier models). They royally messed it up so we resorted to ordering for a 2nd hand one. I stressed them out it had to be from a same 4.4 V8 petrol because if it was from a TD6, coding would be required. Similarly with your warnings case, the lights would go out only to return shortly after. They did not want to touch it (!) and kept telling me how it's all the same and no such thing as coding was possible. Oh and that I likely needed a new precharge pump at €300. Utter rubbish. After 20 minutes and 50 Euros at my then indy, all was good again. ![Thumbs Up Thumbs Up](images/smiles/icon_thumbs.gif)
