![]() | Home > Maintenance & Mods (L322) > Steering Adjustment |
My steering adjustment stopped working but it turned out to be a CCF change I had made in error. During the investigation I came across youtube video's of failed motors and mechanisms which seem likley to be your issue if it's noisy. 2012 TDV8 Vogue (L322) |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Thanks JayGee for your response. I'll get it booked in and checked but I as the whole unit was taken out to fit a new angle sensor I suspect the problem has arisen when refitting to the car. Surely everything should have been checked before handing back to the owner? |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
Seems like something got inadvertently messed up during the SAS replacement.
Many thanks vs322,
The entire jack screw is greased. Not sure of the grease though. I would insist they thoroughly cleaned the old grease prior applying the fresh one.
Thanks Again for your help! |
Glad to be of assistance |
From bad to worse I'm afraid but hopeful an answer will be in sight. After the SAS was changed the adjustment fault became apparent but the car was little used until the wheel alignment that was necessary was rectified. ATS here were very helpful.
What exactly are the warning lights and messages appearing? |
Hi vs322
Let's start from the easier ones. Did they program the new SAS with the car's VIN number? And if so, did they perform a calibration? Although never done it, to know what it actually entails, I think you can "renew" the SAS from the IID tool menu and I'm certain you can calibrate the SAS from the same menu.
Hello vs322
So it appears that your problem is intermittent, am I getting it right?
Thanks for your comments. The the track ends and bars were only replaced after the garage had replaced the SAS. Prior to this the warning images did appear but would not show again after the car was immediately restarted and driven, with a gap of several weeks and short journeys.
