Home > Maintenance & Mods (L322) > Car completely dead
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
Car completely dead
Evening All, I'm looking to see if anyone has experienced the same. Took the car away over the weekend that was a 2 hour drive on Friday, parked up and drove 10 minutes the next day. Left it there from around 10 until 5 and the car was completely dead. Tried jumping it over jump leads with no luck. Even tried to jump it with a commercial 12/24v booster pack and not even the starter would kick in. Luckily my father brought a new minibus battery with him as well as a booster pack when he came to my rescue so fitted that and fired straight away.
Post #673137 11th Sep 2023 4:27pm
JayGee
How old is the battery? 2012 TDV8 Vogue (L322)
Post #673139 11th Sep 2023 4:36pm
JoshVogue94
It was changed around 6 months ago, have been having the "battery low please start engine" message every now and again
Post #673140 11th Sep 2023 4:42pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Iโ€™d be tempted to go into the secret 753 menu and look to see what the voltage is with the engine running, just to rule out alternator problems. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family ๐Ÿ˜€
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #673146 11th Sep 2023 5:16pm
JoshVogue94
Just checked the menu and battery voltage is showing 14.3 volts
Post #673153 11th Sep 2023 6:11pm
chris_read
Thatโ€™s a relief Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family ๐Ÿ˜€
Post #673158 11th Sep 2023 6:47pm
JayGee
I assume this is when it's running and charging. What's the reading when the engine is not running ? 2012 TDV8 Vogue (L322)
Post #673189 12th Sep 2023 9:25am
johnboyairey
Is your no start symptom, a tiny click when start button pushed, and the display going blank? -over and over again? And radio and headlights all ok?
Post #673201 12th Sep 2023 10:55am
JoshVogue94
It did have a click and the display going on and off but I'm not sure about the radio and headlights
Post #673214 12th Sep 2023 12:40pm
johnboyairey
ok, so this symptom has been very popular on the 4.4 l322 diesel. the starter trigger wire has a high resistance joint somewhere in the route from the fuse box to the starter motor. many have simply replaced the starter motor, which sort of gives a fix, but it just makes it easier to spin it up, so the trigger wire fault is not as apparent.... as with a tired starter.
have a read of this thread, https://www.fullfatrr.com/forum/topic31909-105.html
and youll see my post confirming the repair, and youll see the repair details further back. its very easy to run a parallel wire temporary to prove the fault, and then about 1/2 hour work to tie it in on a more tidy route...
..on my car, and others that have done this, the fault is gone forever.....
basically the headlights work, the radio works, but when push the starter the screen goes black, and a tiny click is heard.. so you think the battery is flat, but its not, as lights works etc....
Post #673223 12th Sep 2023 5:11pm
JoshVogue94
Thanks for this mate will have a read, I've tried putting the battery that I replaced on charge with a trickle charger and it's showing 40% which is making me think something has drained it
Post #673224 12th Sep 2023 5:14pm
JoshVogue94
Currently showing 11.9 volts with just the ignition on
Post #673225 12th Sep 2023 5:18pm
JayGee
11.9v is OK with ignition off. 2012 TDV8 Vogue (L322)
Post #673226 12th Sep 2023 5:22pm
johnboyairey
my alternator died once, right outside my house ....fortunately,
it went out in style, with copious smoke and dash bongs galore. but it took the battery out too. by the time i got the terminal off, it had about 9 volts... it was lucky it didnt burst open.
the issue with the starter, was with a perfect seeming battery, at around 12.65 volts.
Post #673231 12th Sep 2023 7:43pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
11.9v is less than 40% charged, a Lead Acid Battery should not be discharged below 50% (12.05v) BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #673233 12th Sep 2023 8:11pm
