![]() | Home > Maintenance & Mods (L322) > Autoglass Windscreen Replacement - Anyone else used them? |
Was driving back from Cornwall the other evening and something hit the windscreen which made a fairly big chip that then started to spider out with cracks by the time I got home.
claud Member Since: 15 Apr 2009 Location: Godalming Posts: 103 ![]() ![]() ![]() |
Autoglass Guildford replaced the heated screen on my Disco 3 last year. I drove to Norwich the following day, only to have the new screen crack from top to bottom. ' |
Mapmuppet Member Since: 03 Sep 2008 Location: Guildford Posts: 153 ![]() ![]() |
Currently on my 3rd replacement windscreen fitted by Autoglass ( Guildford ), and no issues to report. On all occassions professional at all times |
Thanks guys, I'm guessing it totally depends on the fitter that installs the glass.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Can you not get the dealer to do it? I had a BMW a few years ago and I needed a side glass. I asked for a BMW one instead of a pattern one. Insurance Co said I could have it done at the dealer if I wanted to. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
I had Autoglass out a few months back to fix 3 stone chips, 2 on the Mrs car, one on mine. I was chatting to him and in his professional opinion its always better to fix than replace a screen, as he said "it never goes back in as they did at the factory".
Well, they fitted the screen today. I was very pleased with their work and professionalism. They covered the seats and carpets so not to mark them. Removed all trim pieced with care and didn't break anything. They replaced the black trim pieces either side of the windscreen on the door pillars too.
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Dan replace the trim clips if they didnt (Exterior) |
You can't repair a heated screen as we found out a few years ago when we had a Fiesta. We had a starburst in the screen and we got a glass company out to it. The chip turned into a crack and we ended up replacing the screen. Autoglass replaced it and the fitter told me that repairs to heated screens are not recommended as the elements break 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Whilst on the subject of glass- how does the rain sensor work? I can't get my wipers to come on automatically when it gets wet. Does it have to be activated at the dealer? I can only assume a previous owner has had it de-activated. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3765 ![]() ![]() |
non o/e rain sensor screen fitted ? |
It's the original heated screen. I assume the sensor is the section around the mirror? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Yes, here's the workshop manual on it:
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
A stone put a fair old chip (with a starburst effect) in my windscreen in July but luckily it was very close to the bottom of the heater element (mind you, no ice yet to test the affected area). The hole was around 3/4mm spreading to around 6mm within the laminate, but Autoglass used their system to fill it again. It took them around 20mins and on checking the windscreen , I could hardly spot the repair - all I could see was what appeared to be a very small dirty mark (bit bigger than a sharp pencil tip).
