Home > Maintenance & Mods (L322) > Tatty plastics refinish.
Page 2 of 3 <123>
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Fitted.
Post #672616 3rd Sep 2023 8:43am
vs322
Did the left side door handles this morning. Took some sanding to smooth out the top and still, there is some pitting to the plastic itself. Ideally should have applied several layers of base and sanded it down again but quite frankly I don't think it's worth the effort. Pretty happy with the result and I can revisit at any time. Though something is telling me that I won't have to, not any time soon...
Post #672617 3rd Sep 2023 8:50am
Top job, looks much better.... Thumbs Up Pete
Post #672621 3rd Sep 2023 9:48am
vs322
Thank you, Pete. It was a much needed job. Right side ones to follow next week, weather permitting. Those are not nearly as bad as the left hand side.
Post #672629 3rd Sep 2023 1:04pm
vs322
Rear seats trim
The black trim between the seats had also been peeling off. The material is exactly the same as the latch release buttons trim at the top of the seat backs. And so is the treatment. Complete strip down and several coats of black plastics spray.
These trim pieces are held in place by three philps screws and a large tab on the inner curve that hugs the latching mechanism. It takes some recklessness, ahem, courage to remove and even more putting them back but don't be afraid to bend them as necessary; there's no way around it. Then you may as well book with a physiotherapist for your index fingers. Thumbs Up
Post #672731 5th Sep 2023 10:41am
vs322
Too windy to work outside so the door handles on the right are postponed.
Time to deal with the gummy mess that lets down an otherwise near pristine interior.
Steelwool works a treat...
Some wet sanding
That's good enough
Driver's side is worse, with some cracks and sheared tabs...
Two part epoxy to the rescue
After some reinforcement and sanding down the excess material, it's time to paint Thumbs Up
Post #673027 9th Sep 2023 9:56am
vs322
I'm quite happy with the result. I'd give this job an 8/10. Looks a lot better even though the colour came out a bit ... buffier than the original. Still acceptable imho.
Post #673033 9th Sep 2023 11:36am
You can order the correct colour from here....
https://www.furnitureclinic.co.uk/colour-c...lour-chart
Their leather paint is suitable for trim if you use the adhesion promoter and crosslinker, lasts a long time Thumbs Up
Does look good though.. Thumbs Up .. Pete
Post #673061 9th Sep 2023 9:55pm
vs322
Great info as always. Pete Thumbs Up I'll need to find out if they would ship spray cans overseas.
Post #673063 10th Sep 2023 2:59am
I don't think they do spray cans...
I use a touchup spraygun running off a compressor, if you don't have a compressor then the "fill yourself" spray cans is an option or an air brush works well.... Thumbs Up Pete
Post #673065 10th Sep 2023 6:42am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
You can also shop @ the French or German shop.
See the dropdown Menu
Post #673068 10th Sep 2023 8:11am
vs322
Perfect! Thanks all!
Post #673075 10th Sep 2023 11:36am
vs322
The horrible, sticky coating of the cup holders had been peeling for ages. Somehow I never seemed to get around to doing something about it.
Probably because it's a 10' job stripping them to reveal the healthy plastic underneath. Thumbs Up Some Würth dashboard care spray on a microfiber cloth, bit of elbow grease and they're like new Very Happy
PS: Steering wheel spoke covers can be treated the same way to reveal a glossy (almost piano black) finish which isn't half bad, really.
Post #697732 9th Aug 2024 5:28pm
That looks good, and won't wear off, if your door window switches are peeling you can peel it all off and get a good finish, if you think the cup holder took a long time it's a 2min job compared to the buttons...!!! It's a "nearly free" job though... Thumbs Up Pete
Post #697755 9th Aug 2024 9:56pm
Range Rover L322
Great job! I removed the tailgate trim using dental floss.
£28 for a new one from that really great fellow who does all the videos at Powerful UK.
https://www.powerfuluk.com/products/rear-t...rover-l322
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #697758 9th Aug 2024 10:06pm
Page 2 of 3 <123>
