Home > Technical (L322) > ABS fuse keeps blowing up |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Then it will be a component connected to the same circuit and in the same group - yaw rate or steering angle sensor for instance. Check the wiring diagram to see what else the fuse also supplies. |
31st Aug 2023 6:14am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2512 |
According to the wiring schematic that fuse only supplies the ABS module. I would look for chaffed wires between the aux fuse box and the ABS module on a loom section that can move. The bundle is 1.5M long.
31st Aug 2023 7:10am |
albertocsm Member Since: 14 Mar 2023 Location: Aveiro Posts: 8 |
can you please point me to the wiring schematics?
31st Aug 2023 9:48am |
I don't recall from where I got my diagrams but here's the auxilliary engine junction box.
31st Aug 2023 10:25am |
๐๐๐ |
31st Aug 2023 11:22am |
GraemeS, do you know if there is a relay for the ABS module?
31st Aug 2023 12:35pm |
The wiring schematic doesn't show any relays between the fuse and the ABS module.
31st Aug 2023 9:52pm |
