![]() | Home > Technical (L322) > Tow Bar Help Please |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
The tow bars use all the same points as the existing, however you do need to replace the whole assembly which means rear bumper off and the exhaust silencer supported on axle stands.
beemer5711 Member Since: 31 Jul 2022 Location: Wales Posts: 72 ![]() ![]() |
Thanks very much.
Byg Nyge Member Since: 31 Dec 2022 Location: Newcastle Upon Tyne Posts: 31 ![]() ![]() ![]() |
Mine is the same as garyrr, Tow Trust, twin electrics on mine however as my caravan has the two 7 pin plugs.
I'd contact Tow Trust with some additional photos first.
Yeah, I'll give it a clean up and get in touch with them.
JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 67 ![]() ![]() ![]() |
I phoned my Local Witter Towbar Dealer who was extremely knowledgeable / helpful. |
Cheers, ill do that tuesday |
rover75lover Member Since: 02 Aug 2021 Location: wales Posts: 13 ![]() ![]() ![]() |
silly question ,the adaptor isnt hidden in the cubby hide hole on the right hand side ?
The detachable swan neck usually has a part number beginning with ZD (e.g. ZD3004) once you have this number I am sure a search on eBay will yield a result. |
I’ve looked and looked again. Not there unfortunately! I’m also, in wales. Where are you based out if curiosity? Last edited by beemer5711 on 28th Aug 2023 8:36pm. Edited 1 time in total |
Yeah, once I know what part I need, I’m sure I will be able to source one. I have no idea how old this tow bar is though, so might not be so easy. |
Hi again,
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
The electrics look for the load of tungsten stop light bulbs to enable the car to know there is a trailer present. LED's do not draw enough current.
