![]() | Home > Technical (L322) > Torque converter longevity |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
The 260mm F38/A85 converter fitted to the 5-speed petrol models (ZF 5HP24) generally lasts at least 100,000 miles before the TC LUC friction plate wears sufficiently to begin the ‘cattle-grid’ noise & vibration. Mine started at 108,000 miles. As you say, there are many variables which can affect this.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 775 ![]() ![]() ![]() |
Mine started to shudder at about 80k miles. A gearbox flush solved the problem initially, but it came back after about another 20k miles. Then another flush..... then another...... I did wonder if it would have been better just changing the TC the first time round. The older I get, the more I realise that people confuse wrinkles for wisdom |
