Home > General (L405) > Door lock Qs and led status regarding steps
andygts
I'm slowly getting to the bottom of my passenger side step not deploying. I think my front passenger lock is faulty but not coming up with anything on the Iidtool.
When the doors are locked and the passenger tries the pull handle the door doesn't always open, 9x out of 10 it remains locked and you have to use the unlock button.
If you use the unlock button on that door or open the rear door from the inside the step comes out.
If I unlock the doors from the drivers seat the light on my door extinguishes... The other 3 remain lit, if I unlock the doors from any other door the lights remain lit.
Is the led remaining lit normal?
Pretty sure it's the lock that's faulty and not sending an unlock signal when the remote is used or the exterior handle.
And finally how to tell which lock to buy? Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #671926 24th Aug 2023 2:43pm
