Home > My Range Rover > Genuine Land Rover Parts
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
I'll put this thread here as although it's maintenance issue I guess, it's not model specific.
My question is, is it possible to buy genuine Land Rover parts in this case pads and disks? I find plenty of 3rd party, Mintex, Brembo etc but none that are labelled genuine OEM.
Edit: I wrote this after too much time searching. Having written it I then found this for front brake pads:
Delphi £10.44
Ferodo £21.87
Brembo £47.08
Genuine Land Rover £330.32
WOW!! Shocked Shocked Shocked
Post #671771 22nd Aug 2023 4:11pm
JayGee
Yes if you use certain suppliers but you will also find that 'genuine' JLR parts are made by 3rd party manufacturers such as Brembo who also don't actually make them either and outsource them as well... 2012 TDV8 Vogue (L322)
Post #671773 22nd Aug 2023 4:15pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Just go for ‘OEM’
It’s always nice to buy ‘Genuine Land Rover’, but as JayGee said, LR don’t make items like brake parts - so it’s kinda…pointless?
My personal rule is no ‘Aftermarket’ on our FF.
And, don’t be cheap…it’s a FF 😂 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #671779 22nd Aug 2023 6:04pm
caymanblack
I think the price for the Brembos are around £200 i believe. check they are the right ones. overfinch modified
Post #671783 22nd Aug 2023 6:24pm
JayGee
'Genuine' JLR front pads are not Brembo even though the disks and calipers are. This is why they are £££££. AFAIK they are Jurid? 2012 TDV8 Vogue (L322)
Post #671786 22nd Aug 2023 6:43pm
dhallworth
Genuine LR brakes are made by Jurid.
Brembo pads are not made by Brembo either. They’re made under licence by another company with Brembo’s name on the boxes. I’ve never tried them but I’ve read people on here think they’re utter crap.
Post #671794 22nd Aug 2023 8:29pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
I got Brembo discs from Autodoc and I opted for Ferodo pads as they are supposed to be less dusty.
If you install the Autodoc app and check the daily discount - it changes at 11pm each evening. It changes randomly and 41% is the highest I think.
I also bought the spring retainer and pins and bolt kit just to be sure.
£8.95 for delivery from Germany and it arrived in around 9 or 10 days.
Post #671804 22nd Aug 2023 9:48pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, I have been following the YouTuber who also writes on here Overlanding 4x4 L322
He had a brake problem when he used drilled and vented discs with non-OEM pads.
He did say it was probably caused by driving down a very steep hill descent, he has changed back to OEM. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #671815 23rd Aug 2023 7:53am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I changed out all my discs and pads for"Brembos", supplied by Advance Factors, several years ago. Have been all good. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #671819 23rd Aug 2023 8:48am
JamboM3
That is not why they are expensive, they are expensive as they are one of the most commonly purchased parts with high margin. There is nothing special about the pads, they will however potentially be a higher quality than the off the shelf JURID IAM equivalents, probably the anti corrosion qualities and/or quality control - or not!
Post #671882 24th Aug 2023 6:56am
JayGee
When I last looked Jurid pads were superior in terms of low dust. low noise and environmental aspects. I thought they were still overpriced so went with Delphi. They work well enough and the dust is mainly from the disks (i.e iron) so easy to clean off. All pads have to conform to the same friction coeficient standards so can't be more or less effective than OE so you pay the extra for the other qualities. 2012 TDV8 Vogue (L322)
Post #671896 24th Aug 2023 8:12am
JamboM3
Absolutely, backing plate, corrosion inhibitor coating, dust/noise down to material make up.
Post #671900 24th Aug 2023 9:05am
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Brembo pads
Mine delivered yesterday from Autodoc at £90 with others advertised around £160. However you live and learn and will know better next time.
Thanks all Big Cry
Post #671967 25th Aug 2023 8:06am
JayGee
Front Jurid pads for the 6pot for £90? 2012 TDV8 Vogue (L322)
Post #671979 25th Aug 2023 10:00am
Nylands
Brake pads
No JayGee, Brembo.
Post #671981 25th Aug 2023 10:37am
