![]() | Home > My Range Rover > Genuine Land Rover Parts |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Put brembo discs and pads from euro car parts, no issues whatsoever, maybe I was lucky or its subjective bs. |
There is nothing 'wrong' with Brembo pads or disks. 2012 TDV8 Vogue (L322) |
I've got high speed brake judder on mine since fitting Delphi pads / Brembo ( LR branded) disks. Perfectly smooth disk surface and the runout was checked and still a mystery... 2012 TDV8 Vogue (L322) |
My LR branded Brembo front disks are officially warped (as tested by Glenrands) |
Usually failure to clean the hub mating surface or badly refurbished wheels (excessive paint on the mating surface or damaged wheel) causes the discs to distort when cooling. Occasionally a sticking brake caliper piston can cause excessive heat on one side of the disc, this will also cause distortion upon cooling, the effect is cumulative. |
Nice to see you back Phoenix |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 185 ![]() ![]() ![]() |
I went Pagid in the end. So far so good, no squeaks or squeals and the car stops! |
Had pads and disks replaced this morning with Borg & Beck so once they are bedded in I'll report back. 2012 TDV8 Vogue (L322) |
Super Sloth Member Since: 23 Jun 2020 Location: Derbyshire Posts: 25 ![]() ![]() |
There’s a time to use genuine and a time to use 3rd party.
AFAIK no major car manufacturer makes their own brake parts and they are all sourced from specialist suppliers such as ATE, Brembo, TRW etc. 2012 TDV8 Vogue (L322) |
Likely to be that answer to a lot of things? Sanden on compressors / Pirelli on tyres / Philips er Al on bulbs etc…
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
I have just purchased Brembo Front & rear discs. £129 rears and £150 front just waiting for brembo front pads to reduce in price.They have a nice painted hub and vents ,at least they look good. overfinch modified |
The Borg&Beck disks and pads are working out well for me. Nice bite and progressive braking feel, low dust and no noise and more importantly no more judder. Still no idea why the Brembo disks warped so quickly or maybe even were warped out of the box although I do know that cast products can warp due to machining too quickly after casting. May fit B&B pads on the rears as it's an easy enough job. 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8519 ![]() ![]() ![]() |
I use Diamond, best pads ever....
