![]() | Home > Maintenance & Mods (L322) > TDV8 4.4 oil filter housing |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2663 ![]() ![]() |
It looks to me to be a spring to hold some tension on the tube that fits through the centre of the filter element. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1310 ![]() ![]() ![]() |
There's a rubber bung on 'the leaf spring' which covers a hole. I think when you undo the filter for a few turns it opens the bung to let the filter drain. |
If I remember I'll have a look at next oil change to see if mine springs off the hole, which won't be for a while now having only just changed it recently. |
Will check mine and can't see an issue with removing the oil filter part way through an oil service interval. 2012 TDV8 Vogue (L322) |
I was thinking more for the members with oil light problems because they could whip out the oil filter in a few minutes to check.
Mine's oil light goes off immediately on starting but it might not be nice to have an open bleed hole for the next 10K kms... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
I clean mine out every 6monthly oil change, but the spring always stays put.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 906 ![]() ![]() ![]() |
I was missing the plug ( rubber bung ) , so I asked a friend of mine in Miami to get me one, so I can't wait to try it on my oil filter spring, these ones are the new revised updated design which keeps the plug seated better when removing your old oil filter.
been asked to put up a youtube video - sorry about the bad quality but you get the idea |
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 49 ![]() ![]() ![]() |
If this a known problem with ford engines that are also used in RR why is there no fix for RR owners 2012 Westminster 4.4 tdv8 |
because 99 times out of 100 the indy or MD just replaces the whole oil filter/cooler assy at a cost of around £150 and thinks nothing of it, when all that is really needed is a $12 USD part , made by Mahle in Germany for peanuts - crazy world we live in.
