Home > Technical (L322) > Permanent fix for leaking throttle body pipe |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 843 |
Four o rings and everything else exactly per Furnituremans’ instructions 👍 Jonathan
21st Aug 2023 10:53am |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 394 |
cool will do same when it turns up thanks Its actually a sport
21st Aug 2023 10:58am |
fmgl322 Member Since: 18 Apr 2022 Location: Koblenz Posts: 60 |
Evening all. I’ve discovered the source of my air leak and it’s the little hose connected to the throttle body elbow. Can anyone tell me what the dimensions are of this pathetic little piece of wisened old rubber once was on my car? It’s so brittle, when I removed it to check for markings/dimensions, it crumbled in my hand. Still, it gave me the chance to clean the rest of the system and, thanks to FM’s instructions, I’ll be going down the multiple o-ring route to seal it up for the foreseeable.
25th Oct 2023 6:30pm |
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 72 |
Just for clarification you refitted this without the plastic retaining clip that holds back the original green rubber seal? Current 2011 4.4TDV8 VSE 1972 MGBGT Gone 2004 Discovery Landmark 2.5D 2003 Freelander TD4 SE |
3rd Nov 2023 1:08pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 794 |
Thank you for the instructions, I bought a pack of 10 from Amazon, next day free delivery using Prime and for under a fiver - happy days to fix this stupid turbo elbow charged air leak
3rd Mar 2024 11:27am |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Please send a link |
3rd Mar 2024 8:54pm |
sure - but this is the .co.uk site for Amazon
4th Mar 2024 9:03am |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 37 |
Same question has been presented to the OP a few times now in 1 year and 3 months... -07 Stornoway Gray TDV8 |
4th Mar 2024 12:51pm |
I like the idea of this fix, been quoted €280 for new connection and pipe!
4th Mar 2024 8:18pm |
I fitted 3 o-rings on mine, seems to be a much better fit, will check in 1000 miles |
4th Mar 2024 10:02pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4295 |
Sam's Motor and Machines covered this in his latest video.
5th Mar 2024 8:15am |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 101 |
What I would like to add is to make sure all the tabs of the metal retainer ring sit in the groove in the throttle body, all the way around.
13th Apr 2024 6:47pm |
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 63 |
The sensor on this pipe is quite loose on my car. Oil is dripping from around the sensor. Any ideas how to fix that? I really don’t have any RP faults but it is pretty annoying that it is so leaky there. And I surely dont wanna pay for the whole pipe, which costs around 400 euros in Germany 😬 2011 Vogue SE 4.4 TDV8 |
2nd May 2024 6:34pm |
