Home > In Car Electronics (L405) > Upgrade to Touch Screen AC Panel
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi All!
Never being one to leave perfectly functioning items alone, I have decided to bite the bullet on upgrading the Heating/AC/Seats panel to the newer (>2018) look on my 2017 FFRR.
Has anyone done this using the Ali Express (or similar) advertised hardware? - I'm looking for recommendations rather than being a trail-blazer (but if no one has tried before, I'll have a go!)
I have found this - https://www.aliexpress.com/item/1005005505...el=twinner
which looks like it might be suitable but it doesn't (obviously) have a CD slot and I'm old-school so I'd like to retain that...
Or there is this one; https://www.aliexpress.com/item/1005004478...el=twinner which does have the CD slot...
Does anyone have any experience and suggestions (with links if possible)
Thanks in advance! 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #671531 19th Aug 2023 2:44pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I got mine from VikNAV on AliExpress. They have a disc slot.
 Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #671537 19th Aug 2023 4:01pm
the volume and heater controls look very low, are they ok to use.. ... - .- -.
Post #671538 19th Aug 2023 4:23pm
Bora20
Not one problem using either. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #671539 19th Aug 2023 4:24pm
Wrecker79
Thanks Bora20 - much appreciated - I shall take a look.
Did you lose any functionality when you replaced the factory one with this one? 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
Post #671633 21st Aug 2023 9:52am
Bora20
It added functionality as my OEM panel did not have seat heating/cooling and an upgraded OEM panel wouldn’t work.
THe 4-zone climate control temp works on the screen, but the screen only shows 3-zone. The rear controls work fine.
If I had the OEM heating/cooling panel I would not change it. That was my main focus as with the upgraded android main screen it took far too long/too many menus to get to the seat heating in the winter. At -20C, I want to be in the RR for as little time as possible when starting the RR to let it warm up. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #671651 21st Aug 2023 2:28pm
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
Yes the joy of Canadian winter. I had my mech confirm that I have a factory block heater. Land Rover in their wisdom stop providing the cables as standard. Will get a cable fitter for the forthcoming cold season.
Post #672027 25th Aug 2023 8:45pm
Wrecker79
Well.... I bit the bullet and paid my money to VikNAV and eight days later a very well protected box came to my door.
Inside was a very well protected HVAC screen and 15 minutes later it was fitted to my car and working perfectly.
(It would have taken 5 minutes if there had been any indication that you needed to scavenge the spring clips off the old panel to put on the new one)
All-in-all a well made piece of electronics, quite robust to handle and in use, that fitted and worked perfectly.
Now... what should I upgrade next....
W 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
Post #672667 4th Sep 2023 7:57am
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
@Wrecker. Which screen did you get from Viknav- I see they have a few
Post #673391 15th Sep 2023 5:09am
Wrecker79
Looks like I spoke too soon....
I have had to remove the new bits and put the old bits back in as there was/is an issue or two;
1. The car always started in re-circulation mode (it was steaming hot when I installed it, so did not notice this)
2. The automatic fan speed adjustment does not work: if you manually adjust the temperature it does not increase to feed more cold/warm air in as appropriate
3. The back left temperature adjustment (four zone) adjusts the front left temperature.
I am in discussions with VikNav.
I'll keep you posted. 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
Post #673416 15th Sep 2023 1:00pm
vnitos
Thanks. Will wait for your feedback
Post #673555 17th Sep 2023 7:02am
