![]() | Home > Maintenance & Mods (L322) > Rear subframe bushes KHC000050 0r KHC000060 ?? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 ![]() ![]() ![]() |
Gents as above or is it the 50 for the front two and 60 for the rear two dont remember them being different from from to rear ??? |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 ![]() ![]() ![]() |
They are the numbers and different front to rear.
Thanks Kevin you dont have the part nos for the clamp and bolt by any chance ? |
Brilliant thank you |
Yes read about that good shout |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
why does it need altering ( a job I need to do on a couple of weeks ) |
The tool is ok in it's diameter but BMW bushes have a flat top that the tool locates into. Genuine Land Rover bushes have a 15mm protrusion, at the top, so the tool will be pressing on the inner sleeve instead of the outer diameter.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 456 ![]() ![]() ![]() |
hi
