Home > Maintenance & Mods (L322) > Rear subframe bushes KHC000050 0r KHC000060 ??
Sandyt
Gents as above or is it the 50 for the front two and 60 for the rear two dont remember them being different from from to rear ???
Post #671322 16th Aug 2023 7:21pm
kevinp
They are the numbers and different front to rear.
I'm just altering a bmw puller to fit them without damage.
Post #671328 16th Aug 2023 7:52pm
Sandyt
Thanks Kevin you dont have the part nos for the clamp and bolt by any chance ?
Post #671329 16th Aug 2023 7:59pm
kevinp
The plate between the bolt and bush is
'Frame mounting insulator' RGL 000021, £12.20 [ if that is what you are calling a 'clamp']
and the bolt is RYP 100161, Bolt M14 x 1.5 x 138mm. £6.76. Thumbs Up
Post #671337 16th Aug 2023 9:51pm
Sandyt
Brilliant thank you
Post #671342 17th Aug 2023 12:39am
kevinp
Also worth getting some of this mate.
LR012582
Post #671344 17th Aug 2023 2:35am
Sandyt
Yes read about that good shout Thumbs Up
Post #671345 17th Aug 2023 7:00am
darrenm
why does it need altering ( a job I need to do on a couple of weeks )
Post #671393 17th Aug 2023 2:41pm
kevinp
The tool is ok in it's diameter but BMW bushes have a flat top that the tool locates into. Genuine Land Rover bushes have a 15mm protrusion, at the top, so the tool will be pressing on the inner sleeve instead of the outer diameter.
I suppose I could cut out the centre of the bush so the tool will fit but I am looking at making a spacer first.
It's basically the same problem with pressing the new bush in as well.
Have you got the BMW style tool?
There might be different ones possibly??
Post #671404 17th Aug 2023 4:40pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
hi
i know its an old thread but do you have the part number you used it get them out and in ?
thanks will
Post #690874 19th Apr 2024 6:44am
